Question about HP Office Equipment & Supplies
HP Designjet Z3100 Photo doesn't want to start up after 6 weeks off. Error 21:13 Restart the printer. If the problem persists, call HP support. What could I do to get it running?
Posted by Robbert Kamphuis on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
Anonymous
SOURCE: hp designjet 500ps having problem
system error 81:01
Posted on Jan 07, 2009
jose rea
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
Anonymous
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Posted on Sep 04, 2009
pkr03k
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
Z3100 error code 21.1:03
please get a hp skilled technician to have a look at the printer or give hp a call on 0860001030
Nov 07, 2013 | HP Designjet Z3100 InkJet Photo Printer
Error code 21.1:03
there is a solution in the user manual but the best place is to go to office equipment repaerer tyhats vlokal to you
Jun 17, 2013 | HP DesignJet Z2100 InkJet Photo Printer
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Error code 87:10
Plz give detail of your problem to identify the cause and solution.
Oct 16, 2012 | HP Designjet Z3100 InkJet Photo Printer
How to bypass cartridge has expired error ??
Only way that I know how is to replace the cartridge with one that has a good date.
Aug 23, 2011 | HP Designjet Z3100 InkJet Photo Printer
Error 48:00
48:00 error is a PPS(Paper to paper space) system failure.
You need a trained tech to look at the machine.
The PPS solenoid cable could be damaged. Could be a bad PPS solenoid or a bad print mech
Nov 09, 2010 | HP Designjet Z3100 InkJet Photo Printer
Hp designjet Z3100 photo plotter 79.04 error
It Seems It Could Be a issue with Formatter
but still We Can Do A Emergency Firmware Upgrade ,Mail Me For Detailed Steps
Apr 06, 2009 | HP Designjet Z3100 InkJet Photo Printer
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
