Question about Sylvania Televison & Video
I am asking for a Sylvania 2009 TV that I don't have the remote to. Any help appreciated. The volume is constantly going up and I can't get it to go down. When I press the volume down button, setup opens and starts going haywire and changing settings. I have already left it unplugged for 8 hours and the problem persists. Thank you to anyone willing to help
Posted by DCaffeine 18 on
5 Related Answers
Anonymous
  • 337 Answers
SOURCE: No Power to TV
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Nov 08, 2006
Anonymous
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
Anonymous
SOURCE: SYLVANIA SRCD227 REMOTE CODE
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
Posted on Oct 08, 2007
pcland_com
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
Anonymous
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
Remote sensor on tv not responding I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley...
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Jul 17, 2012 | Sylvania LC420SS8 LCD TV
Why does my volume keep going down on my sylvania tv
Just check whether the volume down button on the remote or on the TV is jammed. Else, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Sylvania LC320SLX 32 in. LCD TV
the problem is the s/w on the tv if you have some solder experience this is easy to fix just repalce the s/w
Feb 12, 2012 | Sylvania LC420SS8 LCD TV
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Jan 14, 2009 | Zenith ZEN450 Remote Control
Remote codes
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Was this solution helpful? Show your Appreciation by rating it:
Nov 08, 2008 | RCA RCU600M Remote Control
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
Sep 20, 2007 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Televison & Video Logo
13 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
