Question about Crate Music
Schematics far crate amp gx-30m - Crate Music
Posted by Jay Wise on
2 Related Answers
Anonymous
  • 157 Answers
SOURCE: Crate GX-20M burned resistor + popped cap values?
go to
http://www.crateamps.com/support/index.php
you may find what you are looking for there.
Posted on Aug 20, 2009
CJstout
  • 12 Answers
SOURCE: How to fix the input plug on a Crate GX-15 guitar amp.
Michael, I'm thinking from your post that this is a standard 1/4" "Phono Plug" - a super common connection for audio gear of all sorts. The crackling sound is from the connection between the plug and the jack (being broken) and the amplifier amplifying the moments it connects and disconnects. If there were more power running through it like a high voltage, you'd could actually see with your eyes what is happening, but in this case, low power, we use our ears.
SO- Those input jacks are readily available at parts stores. You'll see that you can unscrew an input jack from the socket or hole it's in and replace it, connecting it all together again with a soldering iron.
If the plug itself is cracked (its plastic, right) and the wires are not connected internally, same deal. You can get that part all over and do the same thing. Connects the two wires the same way to the new one as they are in the old one.
Get used to this problem.....these input phono plugs and input jacks get damaged easily and often. There are better connections like XLR and others that won't break as often and actually lock onto the case, but with what you have, care, caution and an occasional fix are part of life.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chad_65e28e99f5372e81
Posted on Jan 02, 2015
I NEED THE SPECS FOR THE CRATE GT-200 AMP MAIN TRANSFORMER
Contact the Crate Service Department at 1-800-738-7563 or 314-569-0141 (8:30am-5:00pm central time, Monday-Friday) to order any parts and/or schematics.
Aug 05, 2018 | Crate Music
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Feb 21, 2018 | Crate Music
Where is the fuse located on a Crate GX-15?
make sure it's unpluged! then take out the chassis, and look for it on the circuit board. I don't think that one has one.
Oct 09, 2016 | Crate Music
Gx 15
Amps have fuses inside. Check them if they are blown. After replacing, if it keeps blowing, then you have a short that needs to be fixed. Good luck!
Mar 27, 2014 | Crate Music
I need schematics for this amp. know where I can get them?
Josh,
I also need schematics for this amp. How about whoever finds it first shares with the other?
Cool, Thanks,
bob at stumpweb.com
Jan 27, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
13 people viewed this question
Top Crate Music Experts
rhodesworks
Are you a Crate Music Expert? Answer questions, earn points and help others
