Question about Tools & Hardware - Others
Does anyone know where you can find parts for a mastercraft belt sander. Bushing in front roller melted plastic - can't seem to find part anywhere - also same part number for Crafstman belt sander.
Posted by Bruce Hicks on
Jackline Nyaboke
Amazon
Posted on Oct 23, 2020
I require a charger, model # 5104-14-2. Thanks.
I do have one for sale. How much are you willing to pay for it.
I just replaced my mastercraft drill for a bosch one. I live in Canada and could sell this part to you for cheap.
Give me news.
Christian Girard
[email protected]
Jul 31, 2014 | Ryobi Mastercraft Belt/disc Sander Belt...
Need a manual for a mastercraft 55-3554-4 sander
If you find best disc snaders in 2018, easy to assemble, easy to use go to the link Best Disc Sanders For Sanding In 2018
Dec 20, 2013 | Ryobi Mastercraft Belt/disc Sander Belt...
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
Belt sander Craftsman 315.117150 The spring-loaded bolt that adjusts the front roller has an eye hole into which a spring is fastened to the roller. The eye has broken, consequently I am in need of a new...
Alright, I found the breakdown and it is not a very good one. I think I know the part number that you need, but I would feel more comfortable if you would look at it yourself, because the last thing you need is confusion.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Sander-Parts/Model-315117150/0247/0743000/00013345/00002?blt=06&prst=&shdMod=
You can also purchase this part right from the link. Their picture shows the spring actually attached to a small rod on the ordering page. Let me know if this helps.
Nov 26, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Black & Decker 3X21'' belt sander (#7447)- pushed front roller in to put on new belt, can't get it to spring back out. Jim in Flippin
I have one of those and I just smack the front roller ahead with a brass or plastic hammer. I hit the movable bracket that the roller is attached to. It takes a pretty stout whack to do it though. hope this helps you
Jan 14, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
Tools & Hardware - Others Logo
18 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
