Question about Koolatron Refrigerators
No power coming on at all on koolatron ec-23 - Koolatron Refrigerators
Posted by Sarah Needom on
4 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
Posted on May 30, 2008
Kevin Rezendes
  • 269 Answers
SOURCE: koolatron m# ec-23 # 0606027131
The EC-23 machine. If it is making the clicking sound . Unplug it empty it. unscrew the 6 screws holding the back on. You will see a couple of circuit boards. You want to repair the upper right board. It has a 1000uf 13.4 volts Capacitior that has failed. You can unsolder it remembering where the negative side is and positive side. Replace it with a 1000uf and any voltage above what the cap says. Never go under the voltage specified. I put a 45v 1000uf. I found these at Radio shack. Put the new one in. Put it back together and your good to go. Most important is to put the new Cap exactly the same way keeping in mind negative and positive. I don't hope it will work. I know it will work!. lol Follow my direction and the machine will be like new.
Posted on Dec 24, 2010
multilinkent
HTS Sri Aman
  • 739 Answers
SOURCE: When I plug in my koolatron EC-23 the power LED
Hi..
My suggestion, either you change it with their own parts.
but if you are confident with your decision, make sure the computer power supply you are using is same with the parts you mean. whole must be the same like, pin power connection, power supply in and out, and so forth. make sure they are completely the same as a whole, because the wrong power supply may damage your main board.
regards
Posted on Feb 22, 2011
sayayindark
sayayindark
SOURCE: how to make cans get colder in koolatron vending machine
Try this:
Posted on Apr 21, 2012
I have a kolatorn ec-23and the fan doesn't run
does the compressor run? if the fan is not running then it may need to be replaced
Jun 03, 2014 | Koolatron (059586509889) Beverage Cooler
Koolatron p95 cooler doesn't work in car
Check the fuse in the power plug of Koolatron unit.
Also check the fuse for your power outlet in car.
Inspect the power line, any damage, if so replace.
If the unit still does not work, you may have to contact Koolatron
Oct 21, 2009 | Koolatron P-85
Cooler fan fried
Check at your local truck stop. like a T/A or other large chain.
They have replacemant motors and power cords.
Jun 07, 2009 | Koolatron P-85
Koolatron P27.motor fan open.
Parts for most Koolatron units can be found at some of the larger truck stops. Like T/A
Look in the area where they have them on display, you will see the motor and power cords.
Jul 25, 2008 | Koolatron P-85
May 30, 2008 | Koolatron (785169015699)
Koolatron vending machine
customer service helpline at 1-800-265-8456
Apr 23, 2008 | Koolatron (785169015699)
KOOLATRON VENDING MACHINE, FAN WILL NOT WORK
Dec 15, 2007 | Koolatron (785169015699)
Refrigerators Logo
13 people viewed this question
Top Koolatron Refrigerators Experts
Andrew Taylor
Andrew Taylor
Your Consultant
Tom Chichester
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
