Question about Samsung Televison & Video
Hi i have a smart tv samsung when i start it the screen stays black, and the red light blinging 5 times, can you please explain to me is going on. Tv model number is UN40F6300AF. thanks in advance.
Posted by Kamil Dahdal on
KBeaN1
    Habit-Forming:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
I found a site that explains this problem. Hope it helps!
https://www.digihelpdesk.co.uk/what-to-do-if-your-samsung-tvs-red-light-is-blinking-5-times/#:~:text=Samsung%20TV%20red%20light%20blinking%206%20times,be%20an%20HDMI%20hardware%20glitch.
Posted on Sep 26, 2020
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
Posted on Jun 12, 2008
tracy_a
Tracy Accardo
SOURCE: Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Posted on Dec 31, 2008
Anonymous
  • 240 Answers
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Posted on Jan 13, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: BUSH LCD 27 inch
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Anonymous
SOURCE: Samsung HP-4252 screen goes black
I have the same problem, and it will get worse. I have read and seen video on youtube, stating that it is capacitors on the power board, that need to be replaced. I watched the tutorial video it seems pretty easy, I am going to try it this weekend. Will update.
Posted on Jul 23, 2010
Samsung Tv UN46F6350AFXZA Pwr on, Logo appears, Smart boxes dispays 5-secs, then go black, Red lit go off, but back lit on for 21-secs. then back lit turns off & Red light turns on. Ready...
Cable connection problem: Your Samsung Smart TV is likely to have a black screen issue due to the cable connection problem. Loose connections, damaged cables or inactive power sources are the probable cause of the problem on your TV. ... If the menu appears on the screen of your TV, then the problem is with the sources.
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
How to Bluetooth pair a 65"seiki smart tv model# se65upc4t to a Android phone.
go into your android phone and go into bluetooth and go into bluetooth settings on your smart tv know the bluetooth name in your smart tv,check it on your android and pair both
Hi I got a 60" Samsung smart tv end it won't turn on I got a red flashing light I counted the light end it flashed 10 time what can it be end how can I fix it thank you in avence.
Unfortunately, this problem may require servicing from Samsung. There is a video online explaining how to fix the problem, but it involves removing the back panel of the TV.
I don't know how old your TV is and whether or not it's under warranty. The safest thing to do is to contact Samsung for repair. In the meanwhile, here's the video if you're adventurous enough to try it:
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
My samsung 16:9 in tv.
Hi
I have the same proble. I phoned Samsung today & explained the tv was only 14 moths old & had a
black solid line down the left hand side of the screem, they didn't wanna no & hung up on me, so I phoned Dixons & explained to them, they said get an independent engineers report done & send the report to us, we will fix it if we can & if not we will send you vouchers to the value of the tv. Dixons also said it was a known problem with the LCD screen. Watch this space & my advice stay away from samsung
Open Questions:
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
