Charger light not coming on at all - Computers & Internet
Posted by Alison Horner on
  • Larry Ng
    Larry Ng Sep 26, 2020
    alison what is in your (at) hand.
    vast things have chargers. even bluetooth speakers, laptops.,netbooks,notebooks ,tablets.
    and more.
    you posted to computers, so what computer is it.
Metal
    Problem Solver:
  • 14 Answers
Jeesus, some people can't even ask for help right!
Posted on Sep 27, 2020
I have a Bruno stairlift with a 24 volt charger. The charger will not work. The red light comes on but the green light does not come on
hi
it ether the battery come to the end of the life time
or more likely the diodes have blown in the charger
Jan 10, 2018 | Drills
My red charger light on a ryobi charger will not come on
Try connecting the charger into another mains outlet and if the charger light still does not light up the the charger is faulty and needs to be replaced.
Nov 09, 2012 | Computers & Internet
My gentouht charger light comes on but it dont come on at all
the battery must be dead, I plugged the charger into the wall and attached it to my computer. Well, the light was green on the charger, but when I plugged it into the laptop, the light went out on the charger and the computer still wouldn't come on. At first I thought it was the charger, but after testing out different sockets and getting the same results, I believe it's the computer. This computer is brand new and I was just on it the night before and everything was fine. Any help is appreciated.
Aug 08, 2012 | Augen The Book 7-inch e-book Reader...
Aug 08, 2012 | Augen 7" The Book eReader EBGA701 -...
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
Sep 29, 2010 | Health & Beauty
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Charger light does not come on
The red light indicates the batteries are charging and green indicates the charging is complete.
Jun 12, 2010 | Stinger Streamlight 75000
Unit will not power on. Light on the charger does
if the light is not on, on the charger, check the fuse in the end of the car charger...the tip unscrews and there is a tiny fuse just under the tip.
if thats ok, check the fuse to the outlet you are using in your car.
if the light comes on the charger and it still wont charge, let me know and i can help you fix it.
the 3140 are known for there bad power ports.
bill
Dec 28, 2009 | Magellan Maestro 3140 GPS Devices
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Jun 26, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Computers & Internet Logo
14 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
