Question about Electrical Supplies
My 1/3/ horspower automatic sump pump is 1year old and stopped working . when i raise the float it just hums like it is seized up. The seller wont refund because i didnt have a reciept.
Posted by michael bessette on
Carl Rock
  • Electrical S... Master
  • 2,624 Answers
Check that debris has not jammed the impeller. Small stone or piece of wood or wire, even a thick layer of sediment can prevent the impeller from spinning.
Posted on Sep 25, 2020
  • Carl Rock
    Carl Rock Sep 25, 2020
    If you paid by a credit/debit card you should be able to determine the date of purchase by your card records. Once you have the date and amount you should be able to given them the date and card number and amount and they can print the receipt for that date and amount.
    I'm sure the clerk will give you all kinds of excuses why it cant be done, but it can. Call the corporate phone number and explain what happened. Be polite and assertive and keep working your way up the food chain.
seanyboy
    Habit-Forming:
    Scholar:
  • 109 Answers
Take the bottom cover off (unplugged of course) and look for any foreign object. I had a 10,000psi hydraulic ram pump stopped by a finish nail.
Posted on Oct 11, 2020
J Rosado
  • 1,201 Answers
Will it turn by hand? (power off). Sometimes debris will jamb the impeller.
Posted on Sep 26, 2020
Sumps got a liberty 403 ejector pump hooked to slop sink, vented & drains to water waste line. works well used rarely, recently after 18 snowmelt & rain it stopped going on, leaks from top & smells.?
First check and make sure you have power to the pump. If you do have power, either your float switch is bad, or it is hung up somehow preventing the float switch from rising when the water rises. Remove the lid, and check to see if everything moves freely. After determining that the float is free, grab the float switch, raise it manually, and you should hear the pump turn on. If it doesn't turn on, replace the switch.
Apr 22, 2017 | Plumbing
How do I get the sump pump floater to work?
Is the floater on a dongle cord or does the floater slide up an down on a shaft? Are you saying the floater won't float? It seems if you can raise the floater up which contains the switch and it works, it should work when liquid makes the float rise. Is the sump placed low enough in the liquid to ensure the float will rise high enough to turn on?
Apr 30, 2014 | Plumbing
Pump stopped pumping water, only hums when you activate the floating switch
Is there something stuck in the pump rotor if not the start winding went bad
Mar 03, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My sump pump wont kick off. There is no water in the sump and the float is fine, but the motor won't shut off. I unplugged the pump as to not burn up the motor, and thinking it may reset itself, but when...
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Jan 09, 2011 | Flotec Automatic Sump Pump Float Switch
When starting the dishwasher there is only a hum but nothing else happens
The first thing a Bosch dishwasher does when you start a program is run the waste pump. This ensures that any residual water and waste is removed from the machine before the wash program begins.
The hum you can hear is most likely the pump motor trying to drive the impeller. This can become clogged with waste and seize up, preventing the wash cycle from starting. There is an easy way to check this:
(It's easier to do this with the washer empty)
1: Select a wash program
2. Press "Start" and wait for the humming noise
3. Open the door and pull the bottom basket forward or lift it out completely
4. Find and lift the float (the plastic dome/mushroom in the bottom of the washer) all the way up
5. Keep the float lifted and the dishwasher should pump out. Stop if/when you hear a gurgling noise as this means it's empty and pumping mostly air.
6. If the pump doesn't start, lift the float again for about 1-2 seconds then let it drop again for 1-2 seconds. Repeat this 10-20 times and see if the pump starts. The repeated stop/start signals to the pump motor can sometimes free a seized impeller.
If the pump does start, keep lifting and dropping the float switch (1-2 seconds each time) to see if the pump starts every time. If it does, you should be OK to use the washer, but further action is needed to stop the problem returning.
When you've done all this, post the results here and I'll advise you what to do to fix the problem or prevent it from returning.
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Sump pump will not stop. Float is moving freely with nothing in the way. I moved float fully downward and pump does not stop till I unplug it. Please help! Email is [email protected] Thanks!
the pump should not shut off until you move the float fully upward. You should feel the switch actually click when the float is raised. If it doesn't make a clicking noise then something is obstructing the float from being able to rise to its full height.
The entire float ARM, ie the part that is connected to the motor, has to move up and down with the float or it will not work.
Sep 22, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Switching off too soon.
you don't need to replace the switch just raise the upper stop up higher so the float can go higher before turning the pump on, it should have a rubber gromet on it slide it up the rail
Jun 21, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
May 14, 2009 | Plumbing
Electrical Supplies Logo
14 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
