Question about Onkyo Audio Players & Recorders
Model TX-8511. Why did it quit working in the middle of a song - no lights - nothing?
It made a click like the one you hear when operating the power button & died instantly.
Posted by Thomas Evans on
Tom Chichester
    Top Expert:
  • Onkyo Master
  • 60,372 Answers
Power supply failure
Posted on Nov 03, 2020
5 Related Answers
Anonymous
  • 734 Answers
SOURCE: I have an Onkyo TX-8511
as follows to our chat session, please rank me for the solution..
Posted on Nov 16, 2008
Anonymous
  • 734 Answers
SOURCE: I have an Onko TX 8511. It will not Power On
Anonymous
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
wernersaurus
SOURCE: TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Posted on Apr 29, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
I was playing this one song I liked really loud
More then likely you damaged the amp and it will
need to be serviced!
Mar 16, 2010 | Onkyo TX-8511 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Onkyo tx8511. Receiver working fine, power went out
Is channel B switch turned on? If so turn it off .
Feb 27, 2009 | Onkyo TX-8511 Receiver
Jan 28, 2009 | Onkyo TX-8511 Receiver
Nov 15, 2008 | Onkyo TX-8511 Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
