Question about Beko Dishwashers
DSFN 1530. Why does the start button have no resistance?
It operates and switches on but then feels floating as if a return spring is missing Is the return in the push button or the switch
Posted by Terry Booker on
David Spradling
    Top Expert:
  • Beko Master
  • 11,670 Answers
If doesnt feel same as other buttons bad button replace
Posted on Nov 01, 2020
We are trying to replace a door handle on a beko dishwasher DSFN 1530B. We cannot remove the programme panel all screws have been removed and we are stuck. Can you advise
before you can remove the top panel you have to remove the front outer door panel, there are screws down the sides to remove it.
May 14, 2017 | Beko Dishwashers
The start/pause button on my Beko dishwasher DSFN 6831 W is stuck in on position. Lights are on but machine does not start.
I think you have a control board fault, this is the part that is connected to and part of the buttons.
Mar 23, 2017 | Beko Washing Machines
Beko dishwasher light stays on when I have put salt in
Unfortunately, sounds like either the softener (there is an internal monitoring float) or the pcb (which monitors the float switch position) is at fault. Quite often these faults are more costly than replacing the machine. If you remember to top the salt up once a week, then the machine should continue to operate, as the salt indicator is only an indicator for you to top up.
Dec 18, 2016 | Beko Dishwashers
The DSFN 1530 AAA Class dishwasher won't start. the lights are on. there is water in the machine.
Could be the door interlock switches. There are usually two of these. I removed them on my GE and replaced them with an illuminated push button kill switch.http://www.auberins.com/index.php?main_page=product_info&products_id=360
When switch is on the control panel is powered up as well as the rest of the unit. If you need to add a dish after activation you just push the button before opening the door and it interrupt the cycle which resumes with another push.
Sep 04, 2014 | Dishwashers
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
No power to beko 1530 dishwasher
first make sure that power is coming in by checking connection with multimeter.If there is power coming to where it is wired up then the problem maybe the handle swtich either burned out or not making connection when the door is closed
Jan 29, 2012 | Beko Dishwashers
My tablet will not dissolve ?
The usual cause for dishwasher tablets failing to fully dissolve is a failed dishwasher heating element.
Sep 21, 2010 | Beko Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
16 people viewed this question
Top Beko Dishwashers Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
