Heating & Cooling Logo
Chuy Almaraz Posted on Sep 24, 2020
I have a Concept 10 residential AC Unit Installed in 1999 has a bad capacitor, there is no label on it, no manual only serial number and model found Model # is SCU10A36A-3 D what capacitor should I get?
James Clark
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Sep 24, 2020
James Clark
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
11
Questions
0
Helped
9394
Points
44
You need a 40W01 capacitor. 50+5 microfarad. I attached links to some vendors below.
https://shortyshvac.com/index.php?main_page=product_info&products_id=1328
https://www.technicalhotandcoldparts.com/lennox-40w01-dual-run-capacitor/
5 Related Answers
Anonymous
  • 400 Answers
  • Posted on May 08, 2009
SOURCE: Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Yes you should try replacing the run capacitor.
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on Jun 02, 2009
SOURCE: Need size of HVAC dual run cap
Model number please.
Anonymous
  • 614 Answers
  • Posted on Jun 14, 2009
SOURCE: How old and how many tons is my ac unit?
York is 5 ton
Anonymous
  • 232 Answers
  • Posted on Sep 19, 2009
SOURCE: I am trying to determine the specs on my Rheem
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Anonymous
  • 82 Answers
  • Posted on May 10, 2010
SOURCE: need a wiring diagram for capacitor on carrier ac
see page 2 here...the drawing section with H (hermetic compressor) F (fan) and C (common. -- http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38en-1w.pdf
What size run capacitor in an Armstrong scu10b42-1a a/c unit
the service manual covers all this, get one.
or read the side if the cap and it tells you that ,oops gone.
uF and volts AC
no country told and AC power is not the same all over earth a fine dream by MR Tesla, (RIP)
all I can do is guess any of that, 230vac or 250vac or?
model stated is not a heatpump.
not sold now,
scu10b42-1a 10 = seer year 1997 made? seer 10 is mostly banned.
42 = 42000 BTU .
the dual cap for fan and compressor on the out door pad?
that?
I found the install manual SCU (era) and no parts list wiring diagrams yes.
https://inspectapedia.com/aircond/Armstrong-SCU-Series-Air-Conditioner-Manual.pdf
the parts lists are missing at makers site
https://www.armstrongair.com/
ask them for the parts list. your SCU. (by tons/btu and seer) etc.
that PAD units come on as TON ratings, and the cap must match the compressor and the fan there. or fails. and line voltage not told
(my 5ton AC THE CAP FAILS EVERY 3 YEARS) LIKE A CLOCK.
the maker ended support on old SCU10 series.
seems so. 20+ years old. as most are gone now. R22 phased out.
some laws in some countries ban support for that old of AC
even make did as I can see. (gone)
decodes of models then.
The Armstrong SCU-10, a SEER-10 split system AC using R-22 refrigerant, as an AC series was discontinued before 2020. Models included the Armstrong SCU10B12A1012,900 SCU10B24A SCU10B30A SCU10B36A SCU10B42A SCU10B48A SCU10E18A SCU10E24A SCU10E30A SCU10E36A SCU10E42A SCU10E48A SCU10E60A - where the last two numeric digits are a very rough approximation of the SCU's BTUh rating.
no number if front is gen1.
2SCU is gen2, and so on.
gen 4 is now.
no serial told but the decode is here (yy= 97?
  • Armstrong 10 Digit Alphanumeric Serial Number Age Decoder:
  • PPYYM67890 where PP = Manufacturing Plant No.,
  • YY = Year of Manufacture,
  • M = encoded Month of Manufacture and
    Months are encoded Alphabetically as follows:
    A=Jan, B=Feb, C=Mar, D=Apr, E=May, F=Jun, G=Jul, H=Aug, J=Sept, K=Oct, L=Nov, M=Dec.
  • 67890 =serial#
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I have a Armstrong air ac unit and need a capacitor. the one installed has no label. model number SCU10B36A-7
Take it with you to the ac parts store along with the model number. They should be able to match it. Most units use the same caps.
The water heater does not react to lowering the temperature...water is above 130 degrees... This is a whirlpool energy smart residential water heater that was bought and installed in Mar of this year. It...
Product features show on link below
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Energy smart manual shows troubleshooting chart on page 14
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Initially I would guess the temperature sensor is bad.
However indicator light would flash 3 times.
And since both elements have a temperature sensor, it's unlikely that both would go bad at same time.
That suggests the Self-diagnostic Control Box located on top of heater is defective.
Turn off power at the circuit breaker and see if unit resets correctly.
Manual shows 1-877-817-6750 number for Whirlpool parts and warranty.
Your unit is still under warranty, so control box and other parts should be free.
Keep in mind this water heater requires 10 gauge wire and 30 amp breaker.
If you are running smaller wire or smaller breaker, that could affect long term operation of electronics.
I guess this requirement is so voltage drop from element turning ON doesn't starve electronics in control box
On the control panel, the Red and Black wires connect to 240V from circuit breaker.
Wires appear to pull out of socket using needle nose pliers. It will be important to keep wires in same order.
Take photo of your wiring before disconnecting anything.
To order parts, you must give serial number located on label on side of tank.
Serial number will identify your specific heater to person answering phone at Whirlpool.
Installation part should come with instructions, but ask the person at Whirlpool what steps they took during training. Whirlpool rep might have helpful tip they learned during training.
Add a comment and let me know about your transaction with Whirlpool so I can pass it along.
3helpful
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
2helpful
Top Heating & Cooling Experts
Paul Carew
john h
