Hello, I recently ordered a power supply board for my Vizio E601i-A3 due to no picture on the screen, but a background picture visible with the "flashlight test" and there is sound.
Vizio had a recall on this model TV resulting from the issue your having, below is a link to the recall. What they said was recently Vizio put up a special bulletin on its website stating a number of its 60-inch E601i-A3 and 70-inch E701i-A3 HDTVs may lose the picture (but maintain audio) due to a bad "chip assembly". The "chip assembly" is actually in the main board, Ive fixed a number of this model TV's by replacing the main however Ive also seen the lamps fail as well so its kind of a guessing game as far as where the issue is at unless you have some high end test gear to troubleshoot the set. Vizio Issues Recall On Large Screen LED LCD HDTVs
Can be the TCON board or the Main board. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
