• Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip. • Make sure the TV is plugged in. • You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear. • Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator is blinking or flashing section below for more information. • When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can only be turned on after the Power indicator goes off. • Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp. • Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 53. • Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced Options, then Multiple TV Setup. Choose TV (default).
Does the power light slowly blink three times then go out? Do you hear any sounds that coincides with the light blinking? Reply to this same post for further assistance .
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this happens frequently, the voltage in your house may be abnormally high or low. • Unplug TV. Wait five minutes. Plug it in again.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Ck 3 capacitors on deflection board cp150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are 220uf 35v cp114 cp120 resolder all pinns on FBT flyback transfomer.
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
is blinking or fl ashing section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
remote control solutions on page 84.
• Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
