Try this link.
https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0711119.pdf
SOURCE: I'm looking for a manual for a Craftsman table saw model 137.2488
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606545.pdf
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
SOURCE: I need a manual for a very old cast iron 10 inch
Have a look here. Given the lack of a model number, that's the best I can offer, I'm afraid.
Good luck.
SOURCE: manual for table saw model 113299112 serial
You can get the manual on link below. Please allow it to load for about 5 Min's. It is a large file.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0802709.pdf
Good luck and please rate 4 thumbs for the free answer
SOURCE: I have a craftsman table
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
SOURCE: Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Testimonial: "Thank you very much, I'll try Sears first and see if they can help. Since it's an older saw, they haven't been much help up to now."
