Question about HP Office Equipment & Supplies
Officejet Pro 6978. Just installed new black cartridge. Why isn't it printing black?
Posted by Ellen Spann on
doconnell13
    Novelist:
  • 122 Answers
I guess I should ask if you used an HP replacement cartridge or another brand? The printer may not recognize a 3rd party replacement cartridge. Next, assuming you are using an HP cartridge, is it new or a refill? A refilled cartridge may have dried ink blocking the ejection ports on the cartridge.
So I would start with a reset of the printer. remove the ink cartridges. Disconnect the cables, and press the power button for 30 seconds. Then reconnect the cables, turn the unit on and reinsert the ink cartridges. Do a test print. If the black still doesn't work try cleaning the print head.
Click the setup icon and go to Printer Maintenance, click Clean Print Head. You should hear the machine doing this. Print a test page and see if this fixes the issue. If it doesn't or only partially fixes the problem wait 10 minutes and clean the print head again. Hopefully, this will at least improve the issue. If the print quality still doesn't look right wait 10 minutes and repeat the cleaning again.
Hopefully your issue is fixed. If it still isn't printing, could it be your paper? Is it the same paper you were using before? Some kinds of paper do not absorb ink very well.
Hope this helps.
Posted on Sep 22, 2020
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Hp Officejet Pro K600 is not printing black and making the other colors appear saturated and dull
Your ink cartridges seems to be dry/near emtyness, buy a new black and color cartridges and it will print as new.
Nov 29, 2009 | HP OfficeJet Pro K8600 Printer
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
Aug 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The Printer is not sensing the Black Cartage
if their cartridge worked and yours did not. buy a new cartridge.
Jan 27, 2009 | HP Officejet Pro K5300 Laser Printer
Can't get the black ink cartridge to print
Try taking out the cartridge and inserting it again to make sure it was originally put in the printer correctly and not forced in.
Jan 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
14 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
