The list of codes is on page 105. Code E34 is simply listed as contact customer service. Which is not really all that helpful in diagnosing the problem. Have you tried to reset the oven? Disconnect the power cord for 2-3 minutes and trying again? If this doesn't work, given the general code, you should call the customer service number in the manual.
Hope this helps.
https://www.rational-online.com > en-xx > manuals
PDF
The status of the preheating temperature is displayed in red and blue. The end of a cooking process is indicated by the flashing Self-. Cooking Control® button.
Use something similar size to the rational pills, place it where you would normally put the pills for cleaning, go to start the cycle, then pop the door before you press start, should trick the rational into unlocking,
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
