Question about Garden
I have just bought a petrol hedge trimmer model hht 2660 with no manual I need to put some petrol in but am unsure if it’s 2 stroke or straight petrol can you please help ?
Posted by Phil dower on
Carl Rock
  • Garden Master
  • 2,624 Answers
Https://www.fixya.com/support/t13472454-fuel_mix_homelite_hht2660_hedge_trimmer
Check the fuel cap for markings.
Posted on Oct 12, 2020
seanyboy
    Habit-Forming:
    Scholar:
  • 109 Answers
Almost all are 2 stroke. If it has a place for oil togo into the motor-like a dipstick, it’s 4 stroke. If there’s no place for engine oil, you mix your petrol with 2stroke oil. Haven’t heard the term petrol in a while!
Posted on Oct 11, 2020
  • STEVE SPAM REMOVER Oct 11, 2020
    thats because you are not a brit !!
5 Related Answers
preloved003
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
paul nielsen
  • 252 Answers
SOURCE: What mix of 2 stroke oil do I use for a Stihl
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
Posted on Sep 12, 2010
exemplum
SOURCE: I have a Homelite hedge trimmer model HHT-2660.
Hi Leguer54,
I have the same fault with my hedge trimmer, I notice you posted this over a year ago, did you have any success getting yours fixed?
Thanks,
Rob.
Posted on May 07, 2011
scrodamoon
Wesley Gardner
  • 659 Answers
SOURCE: I have just bought a
ushally 50:1
Posted on May 29, 2011
Testimonial: "Thank you for such a quick answer."
Anonymous
SOURCE: I need to know the
2-cycle engines use 40:1 ratio
Posted on Jul 12, 2011
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
Oct 29, 2015 | Homelite Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
HHT-2660 Roto choke Cover missing
Contact homelite online or by phone!
Jan 24, 2013 | Garden
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
cheers pauly46
May 29, 2010 | Garden
I have a Homelite hedge trimmer model HHT-2660. The scissor action of my blades is not functioning and taking the drive box apart I find the centrifugally driven 'cup' has broken away from the spindle...
Hi Leguer54,
Thanks,
Rob.
Mar 13, 2010 | Homelite Garden
Jun 27, 2009 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
