Question about Whirlpool Dishwashers
Whirlpool dishwasher model du900pcd86 won’t stop filling with water from bottom slowly.
Posted by Harley Seabolt on
David Spradling
    Top Expert:
  • Whirlpool Master
  • 11,652 Answers
Either full water sensor bad or water solenoid stuck open
Posted on Nov 01, 2020
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
Water coming out bottom of door on wash cycle.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
Jun 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Fills with water when not in use
this is meant to happen
May 17, 2009 | Dishwashers
No water
you should have a little round white mushroom looking piece on the inside bottom front right corner of the dishwasher tap it and see if it goes down and then it should work
Dec 22, 2008 | Dishwashers
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
12 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
