Question about Eljer Home
My Eljer 141-4500 toilet has the Fluidmaster flush valve. The toilet flushes but won't refill. If you turn off the water supply and turn it back on, then it refills no problem. But it does not do this when you flush. Help
Posted by Angie Alexander on
Tom Chichester
    Top Expert:
  • Eljer Master
  • 60,372 Answers
The Fluidmaster valve is clogged or defective.
Posted on Nov 02, 2020
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
Im a woman so i dont know much about this stuff but my toilet bowl wont refill and i need to know what to do... i have a fluidmaster 200a
Take off the cover and look at the mechanism when you flush. It's possible the set screw that keeps the flush rod in place has just loosened. If not then the easiest way to deal with this is to replace the Toilet Refill Valve. Turn the water line at the base of the toilet to off. Flush until most of the water is out of the tank, the go to Home Depot and buy this:
Fluidmaster Toilet Tank Fill Valve 200AX The Home Depot
Unscrew the old one and screw in the new one.
May 03, 2015 | Home
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
After flushing the toilet with the fluidmaster 300 installed, and during the tank refill, the refill valve emits an extremely high pitched squeal until just a second or two prior to the tank being...
hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
Jul 26, 2011 | Home
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
Occasionally after flushing ,water continues to trickle slightly in toilet bowl. Have changed flapper twice. Wondering if the seat that the flapper sits on is worn or something. It looks ok. Have a one...
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Feb 27, 2011 | Eljer Toilet Onepiece Canterbury ...
When flushed, the toilet (sounds like a lite scream)
try to replace the fluidmaster it is either that or your supply line is kinked,that or check the little black hose inside the toilet tank make sure that hose is not kinked,if neither hose is kinked replace the fluidmaster
Mar 11, 2010 | Eljer Toilet Onepiece Canterbury ...
I have fluidmaster in my mancesa toilet. After flushing the toilet tank doesn't refill unless I turn off the water supply and turn it back on. What do I do to fix this problem. Wayne
First thing to do is figure out if the problem is with the fluidmaster or with the shutoff valve. If the water doesn't run at all after flushing, then instead of cycling the shutoff valve, just loosen the nut where the supply tube attaches to the fluidmaster (under the tank). If the problem is in the fluidmaster, it will start to squirt out at you, otherwise it won't. Then you know what to disassemble and attempt to repair, or replace.
Jan 29, 2010 | Fluidmaster Plumbing
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Home Logo
18 people viewed this question
Top Eljer Home Experts
Bruce Robin
john h
Mike
Are you an Eljer Home Expert? Answer questions, earn points and help others
