Question about Garden
Miele retractable power cord. How is the spring wound?
Posted by Daneil on
Vernon Taylor
  • Garden Master
  • 6,993 Answers
Retractable things - hoses and cables and even the mower recoil starter rope are invariably powered by a clockspring.
One end is anchored to the stationary casing and usually the centre is anchored to the rotating part. The spring is pretensioned by an amount sufficient to retract the hose, rope or cable all the way and then pulling out the rope, etc. will further tension the spring. The spring end is usually the part that breaks or the anchor.
The spring should be treated with respect as it is usually a great deal longer than expected and should you dismantle a troublesome unit it is very important to keep a firm hold on it because if they are allowed to unravel it is violent and there is a couple of sharp ends...
When a retractable unit ages it often becomes sluggish and it usually helps to wash and dry the spring and lubricate with a few drops of light machine oil or some graphite dust.
Posted on Sep 19, 2020
How do you repair the cord recoil when it won't retract the cord on a vintage Electrolux?
It's very difficult to repair a cord wheel that's not working properly. There is a tightly wound spring that can cause harm if it comes uncoiled. It's best to try to find a replacement cord reel.
Jan 14, 2017 | Vacuums
Pull cord will not retract when assembled. When I took the head apart it works fine.
The question then becomes 'What's stopping the cord from retracting?'
Friction somewhere along the travel of the cord or the winding mechanism is causing this. Find the rubbing point and correct the alignment. Be sure the spring is correctly wound first before re - assembly. There must be spring tension on the winder mechanism to function correctly.
Other than that, check to see if the cord is tangling on itself and preventing the rewind from working.
Jul 17, 2015 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
25hp pull start cord not retacting spring has been replaced
When fitting any pull start spring, you must first pre wind the spring. Once the spring has been at least 1/2 way wound up or tensioned, wrap the pull rope around the spool. When you assemble it and pull the cord, the spring should wind up further to its fully wound position and now retract as normal. If you don't prewind the spring, there will be little or no tension to rewind the rope.
Sep 25, 2014 | Garden
Why will the Pull cord not retract?
I am not sure what your pull rope is on..but most are wound in a spring loaded housing on top of the motor.it may be bound up and not allowing the spring to rewind the rope..if you are mechanically inclined..you can get at the housing by removing the cover where the rope goes in..and do some adjusting..or If broken the complete winding device can be replaced and the cover replaced..good luck
Sep 13, 2014 | Garden
Sears craftsman manuals?
You can't get sears manuals. If you remove the recoil assembly and turn it over you will be able to turn it. If the spring catches and starts to wind then you know your spring is good and you don't have to replace it. If it doesn't spring when wound replace spring. When ready turn till spring is fully wound ( can't wind anymore without force) then back it off until the rope holes line up. Install rope and handle and retract slowly. Pull handle a few times to make sure its not sticking and retracts properly. Reinstall on engine
Jul 27, 2014 | Garden
The lead on my miele hover wont go back in when you press the button ialso dont think it is out fully
This might be the spring that retracts the cord. See if you can pull it out any farther. If not then the cord could be out of the guides or the cord is wrapped on the pulley wrong. If you can pull it out and it wont retract at all, the spring is loose or broken.
Jul 18, 2014 | Miele Vacuums
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
