Question about Bosch Kitchen Ranges
My BOSCH free standing electric range intermittently does not achieve set temperature, why?
Posted by Sandra Harris Snyder on
Tom Chichester
    Top Expert:
  • Bosch Master
  • 60,169 Answers
Erratic temperature control
Posted on Nov 02, 2020
1 Related Answer
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: Have a Whirlpool 30" free standing electric range.
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad again. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 14, 2011
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
19 people viewed this question
Top Bosch Kitchen Ranges Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
