Question about Ariens Garden
I have a Ariens 915017 ezr 1542, how do I remove a deck pulley spindle?
Posted by June Anderson on
5 Related Answers
co7196
Ned C Cook
  • 3433 Answers
SOURCE: How much hydraulic oil do I put in my
Hydraulic Oil?
Posted on Jun 20, 2009
Anonymous
  • 218 Answers
SOURCE: can someone please help lookingh for belt routing
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Posted on Jul 08, 2009
Anonymous
  • 138 Answers
SOURCE: remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Posted on Aug 22, 2009
Anonymous
SOURCE: My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Posted on Sep 29, 2009
Anonymous
  • 18 Answers
SOURCE: ariens ezr 1742 will not move
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Posted on Jul 09, 2010
Need deck belt diagram for Ariens ezr 1542
Go to the Ariens website for more information.
http://ariens.custhelp.com/app/answers/detail/a_id/15/
Sep 24, 2015 | Ariens Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
Ariens ezr 1742 how can I test the electric clutch for the mower deck?
see if you have power and ground at the connector that feeds the clutch if you have power and ground to the last plug take the clutch off and check the wires as they go into the whindings
May 20, 2012 | Garden
How do you remove the pulley from a spindle, without destoying the pulley
Before you put the socket on the nut on top of the pulley, you need to take a piece of wood and place under the deck in such a manner as to stop the of the blade when you turn the nut. You can also use a set of vice grip locking pliers or a large c-clamp to stop blade rotation also by clamping to side of deck. Then you should have no difficulty removing the nut from the spindle releasing the pulley.
If really helpful, please rate.
Jul 13, 2011 | Mtd Garden
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Need to put a spindle and pulley back on deck but need guide
The best guide you can have is to have the new part in your hand and it will become self explanatory. The one problem I can see you having, is getting the old pulley off. Many times these are on a tapered spindle. So when they tightened them down they are REALLY hard to get off without a gear puller ( You can get one from Harbor Freight Stores for about $15).(draw a diagram of how the belt goes) find the idler pulley and release the tension to the belt, remove the belt. Loosen the bolt on the top of the spindle.(You'll need to place a block of wood under the deck to stop the blade from spinning) apply pressure with the gear puller, remove the pulley, remove the rest of the bolts that hold the spindle in place, drop the spindle through the deck, replace with the new spindle, replace the pulley, replace the belt and start mowing. Next step, look in the mirror and remind yourself that you are the COOLEST person on the planet.
Sep 04, 2009 | Garden
Do decks have to match the teactor?
Not sure about the substitutes. But i will tell you that whatever deck you look at make sure that the spindle heights are the same size as what the originals were. And thats measuring from the top of the deck to the middle of the belt guide
Jul 09, 2009 | Garden
Garden Logo
29 people viewed this question
Top Ariens Garden Experts
Mike
dannydoesita
bryan st
Are you an Ariens Garden Expert? Answer questions, earn points and help others
