Question about Frigidaire Refrigerators
Gallery, Model FDE558GHSO. Where can I get a replacement knob?
Posted by Christina on
Tom Chichester
    Top Expert:
  • Frigidaire Master
  • 60,195 Answers
Possibly from an appliance parts supplier
Posted on Nov 03, 2020
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: The dryer knob won't start the dryer
does it turn and can you hear it ratchet as it turns
Posted on Dec 30, 2007
Anonymous
  • 126 Answers
SOURCE: Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Posted on Jan 12, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Posted on Jan 15, 2009
woobie dog
woobie dog
  • 1273 Answers
SOURCE: Need new range top knobs.
They sell these at appliance parts supply houses. Take you old ones with you, and you should be able to get genuine replacements!
Best regards, --W/D--
Posted on Aug 08, 2009
Anonymous
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery refrigerator freezer and fridge are warm, no air blowing out can hear fan in back, back of freezer wall is iced over. What's wrong with it and how do I fix it?
Replace the timer. It is located in the refrigerator side on the wall behind the temp. contol knobs. Pretty simple job. I has the same problem and a repairman wanted to change the thermostat and the heaters for a few hundred. He never mentioned the timer. Talked to someone else and they suggested the timer and they were right. Haven't had a problem since and it's been a couple of years now.
Sep 17, 2013 | Frigidaire Gallery GLHS66EJSB Stainless...
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
My Frigidaire Gallery Top Load Washer will not run ANY cold water!
I would replace the cold water inlet valve at the rear of the washer (pull the washer away from the wall), it is easy to do and the part is less than $20.00
Jan 26, 2012 | Frigidaire FWSB5700DS Top Load Washer
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Where is the water filter on the frigidaire gallery 1999 model?
The filter is in the refer side. Open door and look up in right hand corner of control panel. Push button on right and filter will come out.
My oven does not work but broiler does
Look at the ignitor. Should have 110 volts to it when on bake. Replace if not glowing. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 27 in. Electric Double...
Start knob pulled out and won't go back in (spring loaded)knob came off
Check to see if any part of that knob looks broken.It may have a locking clip that you have to place on the knob first ,so that when you push it back on it locks on.The clip is very small and looks like its shapped like a U/or V
May 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Refrigerators Logo
15 people viewed this question
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
