Question about Tablets & eReaders
Surface RT. What is windows error 0xc0000001?
Posted by Sammy Ndegwa on
Miss Feriel Yawlui
    Problem Solver:
  • 9 Answers
A blue screen with this error code means you can't boot the system normally, this could be as a result of corrupt or missing system files, hardware issues, damaged boot sectors or faulty apps/programs including games from unknown sources.
Posted on Sep 17, 2020
How to add Netflix app to surface 2 tablet
If you have a Surface RT you can only go through the Windows Store and search for "Netflix", then install it. You can also always just to go www.netflix.com from your device and log in to enjoy your Netflix.
If you don't have the RT version, you can just download the Netflix application from www.netflix.com and run it to install.
Happy Netflixing!
Feb 10, 2015 | Microsoft Surface 2 with 32GB
How do I get sky go to work on my Microsoft surface tablet
As far as I can tell Sky Go is not yet supported by Microsoft Surface Tablets running Windows 8.1. They haven't developed an App for the Windows Store yet as far as I know.
Oct 23, 2014 | Microsoft Surface RT
How do I shut down my Surface RT
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
Jul 02, 2014 | Microsoft Surface RT
How do i get my RT to boot
Here are the steps to go back I factory setup. It will remove everything personal you have on the Surface - photos, docs, etc. They will still be in the Share drive if you utilized it for storage.
  1. Restart the device made for Surface.
  2. Press F8 during the initial BIOS post to bring up the Advanced Boot Options screen.
  3. On the Advanced boot options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
  4. Select a keyboard layout, and then click Next.
  5. Type the user name and password of an administrator, and then click OK.
  6. Under System Recovery Options, select Reinstall Windows. This option will restore Surface to the factory image, and any customized user information will be lost.
  7. When the restoration of the factory image is complete, the device made for Surface will restart, and the setup process will begin. This process is identical to the first time you set up Surface; you will be guided by a series of prompts and dialog boxes.
One more note - if you deleted the restore folder to save drive space this will not work. You'll need to take to tech support.
Good luck.
Jun 23, 2014 | Microsoft Surface RT
Is there a way I can get my surface 2 to recognise the ANT pen drive for my Garmin Vivofit.
I assume it's not a surface PRO 2 but just a regular Surface 2. The surface 2 runs Windows RT which only runs specials apps designed for it. It can't run software that is made for regular Windows computers. Unless garmin creates specific software for Windows RT I'm afraid that it might never work.
You can attempt the software found here: http://download.garmin.com/omt/express/B/GarminExpressInstaller.exe but I doubt it works.
What you're trying to do it akin to runnign iPad apps on a Mac, it doesn't work before the architecture is different.
May 05, 2014 | Microsoft Surface RT
Wont boot up
Hi Lisa, because the surface is a fairly new device you should be under warranty, contact windows surface here Microsoft Surface they should be able to help you out.
Apr 10, 2014 | Microsoft Surface RT
Surface rt is slow and freezes
Sounds like you need to do a system refresh, RT is usually quite responsive.
Swipe right to open charms menu, then click on Update and Recovery, then Recovery, then choose "Refresh you PC without affecting your files".
Good luck.
Feb 23, 2014 | Microsoft Surface RT
Tablets & eReaders Logo
16 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
