Question about Maytag Washing Machines
Model lat9635aae. Why doesn't it agitate unless I put the dial on heavy load?
Is there a part I can replace myself to fix it?
Posted by SCOT WESTERGAARD on
David Spradling
    Top Expert:
  • Maytag Master
  • 11,652 Answers
Check under agitator for bad cogs or splines
Posted on Nov 01, 2020
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Older Maytag Washing Machine - Top Loading "Heavy Duty" model
There is a screw near the base of the agitator. If it is missing replace it with a stainless steel screw. If this is a machine that is older than 25 years, you will have to replace the rubber ring on the agitator shaft.
Posted on Dec 07, 2007
Anonymous
  • 63 Answers
SOURCE: Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Posted on Nov 12, 2008
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
Anonymous
  • 1937 Answers
SOURCE: I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Posted on Nov 14, 2009
Testimonial: "that does make sense. I'll try it out on a different cycle. The timer is going through its motions but I'll double check for any loose connections. "
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore 80 series Heavy Load washer, Model
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
What parts do I need to fix my clicking GE Profile WJRE5500G1WW Washing Machine Instead of agitating it clicks but only while under the load of a few towels. With a light load it agitates just fine.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
Here are a few things to check if your washer not agitating: .....Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine on ...
Washer Diagnostic & Repair Not agitating - Maytag ...
? 6:02
https://www.youtube.com/watch?v=MtKGH50DHDk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Repair a Maytag Washer suffering from these following issues:Not ... that stopped working in the middle of a washing cycle leaving full load of ...
Nov 04, 2015 | Washing Machines
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Washing Machines
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer will not agitate with full loads
getting old - thow it out or just use small load
Dec 12, 2007 | Washing Machines
Maytag PAV2300
when you say its the whole thing, is a shaft coming out out with it or is it a two part agitator? if the shaft is coming out its time for a new transmission. if its a two part agitator, replace it
Aug 26, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
