Question about Panasonic Lands Phones
On panasonic kx-tge274 there is no dial tone and incoming calls do not ring and check tel line message is displayed. unplugged and checked batteries. still not working
Posted by Wanda Takemoto on
Tom Chichester
    Top Expert:
  • Panasonic Master
  • 60,372 Answers
Could be a telco line problem.
Posted on Nov 03, 2020
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
[email protected]
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Lands Phones Logo
23 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
