Question about The Office Equipment & Supplies
I have an used Bizhub 500. I was trying to solve a touch panel issue (off center), but i made a mistake. I did the touch screen calibration procedure, but I made a mistake during the process: i touched the calibration points in the wrong way (I clicked over the “arrows” instead of clicking over the “crosses” that appear on the screen during the calibration procedure). After pressing the 4 wrong points, I confirmed the calibration. Now, the touch screen works but it is totally miscalibrated. I can't go back to the calibration option to re calibrate it. If I press microswitch to reset, when "." (dot) shows up on left of screen, I press # 3 button, enter the code (000000) and I get stuck on the "press end", because the screen is miss calibrated. its impossible to click on the touch panel "END" button. Is there a way to do a general reset of the calibration? Is there any option to enter the screen calibration without touching the touch screen? any ideas how can i fix it? Thanks in advance.
Select the Accessibility button ?
Option (1) Touch Panel Adjustment - Touch the four "+" buttons ? Press Start ? Close
Posted on Sep 13, 2020
SOURCE: Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Posted on Nov 13, 2008
SOURCE: Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Posted on Apr 10, 2009
SOURCE: P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Posted on Jun 18, 2009
SOURCE: calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Posted on Jun 21, 2009
SOURCE: N99i touch screen problem
go to settings and click pen calibaration....and it will allow you to move around the screen freely...
Posted on Aug 11, 2009
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
