Question about Refrigerators
Left side french door is not closing properly. How do I replace part? Model RF266ABRS/XAA
Posted by Bernice Svingos on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 60,187 Answers
If the door is not damaged, it may just need adjustment. If you really want to replace the part, you would have to order it from the manufacturer/distributor or an appliance parts supplier.
Posted on Nov 08, 2020
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
How do I replace the door latch?
A good place to view exploded parts diagrams is Sears Parts. See http://www.searspartsdirect.com/samsung-refrigerator-parts/model-RFG297AARSXAA0000/1482/0161000.html. Note that the parts you are looking for could be in the left door diagram or mor likely the cabinet diagram.
Aug 05, 2015 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
I have a Samsung RF265ABBP model. I just finished replacing the ice maker kit and everything works fine. I noticed Ice build up on the left side of the sliding door. It builds up on the fridge itself and...
Could be a gasket problem. But, also on those sliding doors, ice can cause them to not properly close all the way! Pull the door all the way open and check the track/rails for ANY ice. Make sure it is completely free of ice!
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Left side french door seem to have sagged,and now wants to bind when closing.how do you adjust it upward ??
ck the cam ( plastic ) it lifts the door and also causes it to close tight . they ware out and the sometimes just brake and fall out . .. part # 12395501 b -- this is a blk bushing . for your model .. mm
Sep 02, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
