Question about Whirlpool Refrigerators
Looking to get to the root of this issue. I have a whirlpool 18.2 cu ft refrigerator / freezer. I noticed this morning that everything in the freezer was unthawing and the refrigerator was over 40 degrees. This is what I found when I took the inside of the freezer apart.
Posted by Ed Arrow on
  • Ed Arrow Sep 11, 2020
    Thanks David. I thawed it out and the ice ball starts forming in the same place within minutes of being plugged in.
David Spradling
    Top Expert:
  • Whirlpool Master
  • 11,596 Answers
Try letting thaw then plug back in if same happens bad temp sensor or low on freon
Posted on Sep 11, 2020
5 Related Answers
Anonymous
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
Anonymous
  • 149 Answers
SOURCE: Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Posted on Jun 11, 2009
Anonymous
SOURCE: refrig/freez buzzing and not coolng properly after door left open
called Sears Home Repair
Posted on Aug 04, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: whirlpool 6 sense model WSC5513- A+ X side by
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Posted on Aug 20, 2009
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy Star® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
Replace freezer thermostat whirlpool 18 cu ft upright
Ther thermostat is located in the refrigerator, usually on the top. All you need to do is make sure the probe is put back where you found the old one. Good luck
Sep 07, 2012 | Whirlpool 18.2 cu. ft. Top Freezer...
I have a Whirlpool fridge with top freezer.
Almost certainly iced up. Fully defrost and start again. Make sure the condenser is clear and clean
May 15, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Freezer issues with Conquest
    freezer is supposed to defrost? need more info..
    if you need a part try www.appliancepartssolutions.com
    Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
    Problems with Whirlpool 21.0 cu. ft.
    checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
    Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
    Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
    Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
    Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
    Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
    the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
    now the ice has gone, reset the temps and wait to see what happens
    Oct 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Refrigerators Logo
    15 people viewed this question
    Top Whirlpool Refrigerators Experts
    Michael Thomas
    Michael Thomas
    jdthefixer
    Marvin
    Marvin
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
