Question about Health & Beauty
Jazzy 600 ES left motor-unable to clear fault.
Posted by Gia Gee on
ray gallant
    Top Expert:
  • Health & Beauty Master
  • 70,857 Answers
LEARN TO USE GOOGLE
https://www.google.com/search?q=Jazzy+600+ES+left+motor-unable+to+clear+fault.&oq=Jazzy+600+ES+left+motor-unable+to+clear+fault.&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Posted on Nov 08, 2020
1 Related Answer
porkchop_73
SOURCE: Fault codes jazzy 600 power chair
8 lights flashing how can i fix it?
Posted on Sep 20, 2011
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Is there a reset button for fault codes on this 600 ES jazzy.
You can reset or clear the code by turning the chair off and back on. If the error remains you can use a dealer hand held programmer to read and determine the fault code. Then you can begin to fix the problem.
Oct 15, 2015 | Health & Beauty
Left brake fault may not be engaged.
Each motor has a brake system attached to them. One of them isn't working and is sending a fault signal to the controller. It needs to be serviced.
Jan 26, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What is a left brake fault?
hi, the brake on top of the motor on the left hand side ...
Regards
Rob
www.gewizrepairs.co.uk
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I'm getting a 2 bar flash code and just replaced
If you can do this or have someone else do it for you. Switch the motor connections on the main computer of the chair. If the it goes to a 4 flash then you know that the left motor is bad. If it stays at two flash then either the controller or the joystick is bad.
Sep 15, 2009 | Pride Mobility Products Pride Jazzy 600
Health & Beauty Logo
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
