The treadmill has a 'folding' feature for the incline setting. A safety switch must be reading this feature as not locked. Try this. Set the incline to 0% and the speed to zero. Step in front of the treadmill and using both hands carefully raise the whole front until the legs click and lock into place.
To lower the treadmill kneel behind the treadmill. Place your Right hand on the belt and lean your weight on it. At the back of the treadmill on the Left side panel is a lever. Pull this lever until the treadmill stops lowering.
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: I have a Life Fitness T3-0 which shows a
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
