Question about Moen Home
Moen shower controler lost power now wont come back on blank screen
Posted by Kevin O'Connor on
ray gallant
    Top Expert:
  • Moen Master
  • 70,857 Answers
ASK MOEN TECH SUPPORT NONE I HAVE HAD OR USED ARE ELECTRONIC CONTROLLED
Posted on Nov 08, 2020
5 Related Answers
hessmar
Marc Hess
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
Anonymous
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Posted on Apr 06, 2009
Anonymous
  • 235 Answers
SOURCE: moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Posted on Jul 05, 2009
Anonymous
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
jpintore
  • 129 Answers
SOURCE: the shower control valve for my moen 2995 faucet
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Posted on Sep 28, 2009
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
Getting mostly hot from Exacttemp control 4 yrs. old
Moen's website has PDF's available for download on their site. These have pictures and show you how to adjust the temperature control for your model.
http://www.moen.com/shared/pdf/instruction_sheets/ins1282b.pdf
Jun 16, 2010 | Moen & One Handle Tub & Shower Faucet
Have a moen tub faucet put in new o-rings and now it wont stay pushed in to turn off this is a older model that just pulls straight out then turns l/r for hot & cold
a possible problem,there is some thing else in there,take apart again and look in there and maybe flush it out before you put it back together
Feb 20, 2010 | Moen & One Handle Tub & Shower Faucet
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I changed the stem on hot water because shower leaking- now no hot water from shower head when water turned back on- wont pass stem and some spreay from where stem is?
I am not sure what brand of shower valve you have but it sounds like you lost a peice of rubber or plastic in the valve and it has either lodged in the diverter or somwhere from the valve to the shower head. Is it posible that you got the wrong stem or switched stems or maybe it was put in backwards. Wish i could narrow it down for you,Need better info.
Dec 02, 2009 | Moen 87530 Touch Control Single Handle...
Lost volume/force power
did you remove the shower head and check to see if there was sediment in the shower head? also you might want to check the cartridges in flow control on it sometimes they get junk in them
Jul 26, 2009 | Moen Plumbing
Moen one control shower faucet is leaking hot water
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower handle keeps turning it wont come to a stop
Mar 29, 2009 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
18 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
