Question about Bissell Vacuums
I have a Bissell Vacumn model # 9595 a and l need the wire diagram for putting in a new Vacumn cord for my Vacumn Thank You
Posted by Anthony Johnson on
Tom Chichester
    Top Expert:
  • Bissell Master
  • 60,224 Answers
Contact Bissell directly to request the diagram.
Posted on Nov 08, 2020
5 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Bissell
Check the belts first, if ok, does water squirt out of the hose nozzzle, if it does then the heate in the handle asm. is clogged where the tubes hook up to it. If no water squirts out, the the pump isn't working. Pull the top cover off, check all tubes to make sure there is no clog. Make sure the tubes are routed right so as not pinch one, also make sure the piston is mounted on the smart mix knob. and the knob is in the water setting before putting the cover back on. The cap for the flow indictor is leaking are or screwed on too tight. The seal at the bottom of the tank is not on the tank and is missing or sitting in the hole where the water goes.
Posted on Jan 17, 2008
Anonymous
  • 76 Answers
SOURCE: how do I change the belt on my vacumn
there should be some screws on the bottom of the machine. take out the screws and remove the cover
Posted on Apr 19, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: need a user's manual for
You can get the manual on the link below.
http://img.meijer.com/assets/product_files/pdf/1001371_3920_manual.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 13, 2010
J Smith
  • 31 Answers
SOURCE: tok the bissell model 3750-z apart to service it
Yes. Go to a site called "Manuals online". They can provide you almost any diagram you need..
Posted on Mar 15, 2011
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: Power cord has a short
I have a link of an exploded view of your unit that may help you dis-assembling it. Click this LINK.
Jdvillanueva
Posted on Sep 05, 2011
My upright bissell powerforce bagless motor has blown
Did you contact Bissell Consumer Care? 1-800-237-7691
Sep 07, 2015 | Bissell Vacuums
Manual for bissel upright bagless vacumn cleaner
Not knowing what needs to be put back together I am giving
you this phone #....Bissell Consumer Services !-800-263-2535
Make sure you have the Model Number available.
Regards,
Dennis.
Aug 24, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to replace a porwer cord for bissell 68c71
Cut cord at base. Strip wires. Buy a new cord. Rewire.
Apr 23, 2014 | Vacuums
Need to replace power cord for bissell model 6585
A BISSELL Authorized Service Center should be able to help you out. You can find one nearest to you and call them first if you want:
http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Mar 31, 2012 | Bissell Vacuums
Bissle vacuum and stopped working
bad cord or motor. not cost effective to repair.
May 06, 2010 | Bissell 6594 PowerForce Bagless Upright...
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Diagnosing the problem with my bissell quicksteamer plus upright
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Mar 07, 2008 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
21 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
