Hello there and welcome to fixya
Could you tell me if the machine has this issue right before the mid cycle rinse or just after this and does it have any noise or does it just shut down There are a few things you can check I will walk you through each step as we go ok
I just need a little more detail.
SOURCE: Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
SOURCE: Kenmore Dishwasher Model 665 stops
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
SOURCE: my MDB8951 dishwasher stopped working after interrupted the cycle
Go to your electrical panel and, disconnect the power to your dishwasher for about 1/2 hours when you repower it your DW should be reset
SOURCE: kenmore dishwasher 665.1603 no power stopped in
That dishwasher has a thermal fuse that clips on the control board. The thermal fuse is a safety device, and nothing will run if it is blown. If there is no continuity through it, replace it. They run around $20-$30. If thats not it, remove the kick-plate and check the junction box for loose or fried wires where the wires are spliced together. Also check your house breaker box to make sure the breaker isn't tripped.
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
