Question about Alps MD 1000 Thermal Printer
Spotty color print
Color print is inconsistent and spotty
Posted by gmacproducti on
Anonymous
  • 51 Answers
First of all you can remove your color cartage
and check this cartage to simple page
which color is appers
after that refill the cartage from the serge
3ml
3 color in the cartage and every color every point you can refil
Posted on Sep 20, 2009
Savin c9025/ ricoh mp2550 prints dull after changing toner
Download the software associated with the printer from the manufacturer web site to make sure you have the latest version. If this doesn't fix the problem you may have to buy a new print head for the printer. Also try taking the cartridge out and shaking it vigorously.
I have an old ricoh aficio cl2000n. The printing is spotty at best. The colors seem to print though. I put in a new black toner cartridge and it still didn't clear up the problem. I emptied the...
I can give my opinion for free :) lol
You are saying that you have changed the Toner Bottle? Or the fotoconductor Unit (or drum Unit)?
Is your machine cleaned? What do you mean about spotty? Is it with dots?
From what you are saying i can only think that your drum unit Bk is faulty...
Well... i am not giving you much help... but is free right? lol
Change the fotoconductor and give the feedback
3answers
The black ink will not print, new cartridge, is spotty and not readable, barely prints black, printing color documents OK
I am having this problem too! prints color but not black, brand new cartridge, sorry I am no help, but looking for help myself!
1helpful
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Cyan cartridge prints spotty.
Your print head is probably clogged. If you have already tried the cleaning cycle, it's time to take the printer into an Epson repair center to find out what the problem is. More than likely they will have to replace the print head.
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Inconsistent print quality - from black to blurred gray
please don't say that
kodak is very good and your problem is VERY COMMON
If you call 1.800.421.6699 and select option 01 for prints missing black or color in, Kodak will send you a replacement printhead kit for free.
by the way, I don't work for kodak
My Canon Pixma MP500 is printing only black.
Hey, Sound like something is wrong with the color cartridge. Replace the color one and try again. If that fails you might have to replace the printer as it doesn't sound like the problem is software related.
Spotty printing
it sounds like it might be the test sheets. but im not sure
Rimage Everest
Rimage has made alot improvements with their latest Everest 600 printer when it comes to color density and accuracy (the Everest II is now 2 genereations old).
www.techwaredist.com
Alps MD 1000 Thermal Printer Logo
Top Alps Office Equipment & Supplies Experts
Jean Sintulaire
ADMIN Canada
ADMIN Canada
Franco Dosil
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
