Question about Kenmore Washing Machines
I have a Kenmore Series 100 top loader washer that only fills up with about 4 inches of water and then starts washing. How can I get a full load of water?
Posted by Stephanie Raines on
Sydney Lackey
Unfortunately, that is going to be the regular input for those units. To be more "eco-friendly", companies have started making those units only use about 4-6 inches (6 being a big cycle) to wash the clothing. There is no way to bypass this as of right now.
Posted on Nov 03, 2020
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
My Kenmore series 80 washer does not fill up all the way with water even when it is on full load.
on most top load washer the level of water should be no more tha 13 inches of water on a empty tub.the rule of thumb is there should be between two to three holes visible above the water line
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 90 wont fill up to large load level
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
16 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
