Be sure to manually turn on the device you wish to control. Press. And hold the setup button until the red indicator light remains on and then release the button. Press.
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following:
11447 11758 11442
To program the universal remote to work with the RCA LED32B30RQ TV:
Turn on the TV
Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
Press the "TV" button on the remote.
Enter the 4-digit code for your TV using the number buttons on the remote.
Press the "Power" button on the remote. The TV should turn off.
Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance.
Note: The method to program the universal remote may vary depending on the remote brand and model
To program your universal remote control ... for a Westinghouse TV,
try these codes (on your universal remote control)...
00451, 00885, 00889, 01282, 01300, 01577, 01712, 01755, 01826, 02293
If it is a White Westinghouse (TV), try these: 00463, 01661
Universal remotes are cheaper,but those codes u enter for any tvs any models might work might not.No,not any univeral remotes have any particular tvs brands,just a list of a universal codes for the tvs brands it covers.Try website like Remotes.com to buy a remote same as ur original remote.Than u don't care about codes or taking chances of those codes,will or will not work for ur tv.
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
Turn on your TV.
Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
Press the TV button on the remote so that the LED blinks once and then remains solid red.
Enter the first set of 3-digit codes from the list. The LED will
blink once every keypress. After the 3rd digit, the red LED will turn
off indicating that the code was recognized for the device. If the code
was not compatible, the LED will flash several times and you need to
return to step 2 to try that code again or to try the next code in the
list.
After the LED has turned off, aim the remote at the TV and press
ON/OFF. If the device turns off, you have used the correct code and the
remote was successfully programed. If the device does not power off,
return to step 2 and try again with the next code in the list.
Goto this page:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/grayokselect.pdf
follow the instructions for "Searching For your Code " This worked for my White-Westinghouse (though it takes about 20 repetitions to hit the code!)
Hope this helps
Nate Wells
[email protected]
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
