Question about Watches
Fast Track model NK38033SP02. How can I adjust date and weekday?
Posted by Hidayath Razi on
W117-95809151012
Well, I had the same question, since i just advanced my watch past June 31 (since June has 30 days) but now my weekday is ahead by a day. So I started messing with it and found that you advance the date by advancing the time forward. But if you go backwards, the date won't change, only the day of the week... does that make since?
May 07, 2013 | Disney Watches
How to set time in fast track watch with model number 4054PM01
it is quite simple but i admit i had to break my head in the begining. i spent hours looking for a user manual for this model online but didn't find one so i'm posting this solution hoping to help someone who need it as well. all u have to do is when the watch is in normal time mode, press the SET button and hold it till u see the seconds flashing. after a few seconds the hour and minute on the main display will start flashing too. u can adjust the time here by pressing the ADJ button. once ur time is set follow the same procedure and set the date too. remember to hold the SET button till u arrive to the date mode which appears after the time mode on the main display. there u go:)
Mar 13, 2012 | Watches
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
I have Timex SR 920 SW watch, how to adjust the date and day?
Adjust the day of month (1-31) by pulling the crown pin out part way, and turning the pin counter clockwise, incrementing the date arm. Counterclockwise does nothing.
To adjust day of week (Mon-Sun), pull the pin out and rotate to turn minute/hour hands. Each time you pass 12:00, the weekday hand will increment by a half step.
May 01, 2011 | Timex Analog Metal Field 40051 Watch for...
How to set a deboule watch for month, am or pm, weekday, calendar date .... tried to contact company without success.
The watches have 2 buttons on the outside of the bezel, one sets the day of the week and the other sets the date. depending on the style of the watch, these could set the am/pm function. Use a pen to press in the button, each press will advance the date or day by one position.
Aug 21, 2009 | Watches
How to stop chimes on Louis Valentin waterproof digital watch
Press and hold the lower right button to display the date, then press the lower left button. If now all the weekdays are turned off, the hourly signal is turned off too. If the weekdays are turned on by this operation, the signal is turned on.
Btw: does anybody have some information about the vendor of these watches?
Nov 12, 2008 | Bulova Watch
How to set time in fast track watch with model number 4056pp03
HOW CAN I SET CORRECT TIME ,DATE AND DAY FASTRACK WATCH MODEL NO 4056PP03
Sep 21, 2008 | Watches
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Sep 05, 2008 | Festina 161625 Wrist Watch
Watches Logo
20 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
