JENSEN VR187 MONITOR KEEPS SAYING NO SIGNAL I have sound, but monitor says “no signal “
Posted by C bear on
  • 2 more comments
  • Larry Ng
    Larry Ng Sep 03, 2020
    wow no PC told, not even a clue. (vast kinds)
    this is easy, the monitor tells you the video cable is dead, this is true.
    that PC port is in fact dead. (or cable bad video pens bent on cable ends) dead video is what that means. VGA/HDMI,DVI or DP ?
    you have sound, so that tells me there is USB cable or 3.5mm round sound cable from PC to monitor. so that implies the PC is not dead
    'but just the video port is dead,(no port told)
    if the PC is a desktop (not told) the PC can in fact have video card, mine has 4 card ports and 2 more video ports on the main board. 6total ports ! not all 6 are live ever.
    if i plug my monitor into the wrong main ports those are dead. if using video GPU card, then only those CARD ports work did you do that? IDK.
    if you are playing with a laptop say so.
    laptops with that side VGA port? that?
    you must use a hot key to enable that.
    and that is covered in your RTM users manual
    on HP that key is fn+F4 together,
    enables the VGA port.
    and the keys used are not the same on all PCs made on earth.
    NO PC TOLD. at all not even a clue or hint or a photo of it posted.
    here is my HP elitebook
    just one example of may PC, and mostly not yours
  • Larry Ng
    NO PC told why post lacking such key facts no pun.
  • Larry Ng
    NO OS told is it windows 10?
    if yes did the PC come new with w10?
    is the port used VGA,DVI,HDMI or DP?
  • Larry Ng
    tell more this can be easy.
    what port are you using, or wrong port.
    does monitor OSD work
    does monitor work on 2nd PC. (my guess yes)
    does PC fans make sounds spin?
    is PC power LED solid or blinking,? and color.
    if blinking hold PC power button from 4 to 10 seconds and release it. cured?
Joseph Wright
  • Computers & ... Master
  • 1,706 Answers
The graphics card supplying the signal could be bad, a pin could have been bent over when you plugged in the vga cord (if a vga display).
If a pin is bent, be careful bending it back; it can break off easily. Grab with needle-nose pliers or tweezers, and slowly bend. Don't over-bend.
Posted on Oct 21, 2020
My monitor keeps saying no input signal an now won't power up
Sounds like its the video output from your computer. Try installing a new video card.
Jul 20, 2014 | HP Pavilion Computers & Internet
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
Jensen DVD will not play dvds it say no signal and disc error.
It sounds that the optical pickup unit is faulty. Put a disc cleaning disc into the set, and play it once. If the fault is with dust or dirt, it will be cleared out. If not, replace the optical pickup unit.
Nov 26, 2012 | Jensen Q2749J 27" TV
How do I set the clock on a jensen vr187 cd/ car radio
1. If the radio / i-pod is on- turn it off.
2. Hit the 'mode' button until the time flashes (it should be 3 times).
3. Use the Tun +/- button to change the hour.
4. Use the Volume +/- to change the minutes.
5. Click through the rest of the options to change between setting the alarm, how to be woken up (chime, ipod, etc), 12/24 hour format, year, and date.
Oct 29, 2011 | Jensen Car Audio & Video
Jensen VR187 monitor will not go back in or come on.
Make sure you do not have it in Video Mode or Cable mode. Check the menu and see if you have the brightness/contrast/color and see where they are. if they are below 0 then you will have black screen. also, your state might have changed to digital programming so you will only get Canada stations only.
Feb 27, 2010 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
Our new motorhome came with a sirius ready Jensen vr187 radio-how do we hook up to Sirius, and does it need an antenna, or is that part of ''sirius ready''?
Sirius Ready means that there is another piece the company makes that is for sale seperately from the reciever. you need to get the whole sirius system and it will just plug in and play through your existing setup.
Nov 18, 2009 | Jensen Car Audio & Video
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
Jensen VR187 radio/backup camera observation monitor won't work
In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
Aug 09, 2009 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
15 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
