Question about Electrical Supplies
Generator is putting out high voltage. What could be the problem?
Posted by Todd Delahoussaye on
Kardoc
    Top Expert:
  • Electrical S... Master
  • 6,110 Answers
Generator voltage is regulated with a voltage regulator. Depending on what type of generator depends on what type of regulator it uses.
Posted on Sep 01, 2020
3 Related Answers
John Trevino
  • 1420 Answers
SOURCE: High voltage low cycles
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
Posted on Dec 18, 2008
CarlGlas
Carl Glas
  • 283 Answers
SOURCE: I have a yamaha ef3000iseb generator. Runs well,
The model you have shows to be a Inverter. You may have a defective voltage regulator. Visit the below URL for a dealer near you.
www.yamaha-motor.com/outdoor/dealers/dealerhome/home.aspx
Posted on Jul 07, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: What is the "no load"
All though that is on the very high side it is acceptable for a no load voltage... as soon as you put nay load on there it will drop....
You want the voltage to be on the very high side in a no load state so that you have room for it to drop some with a load...
I would not worry about what you have there...
heatman101
Posted on Oct 24, 2010
2007 Chev Uplander 3.9 Could ECM need replaced? Where is it located?
Without testing we'd only be guessing ! You have no idea of the complexity of the electronics on your vehicle . Replacing the ECM would mean a trip back to the dealer to have it programmed . Without programming your vehicle will never start . You had new battery an alternator installed , did it start an run when you picked it up. The charging system on your vehicle is computer controlled . DTC P0621
DTC P0621 : Generator L-Terminal Circuit
The engine control module (ECM) uses the generator turn ON signal circuit to control the load of the generator on the engine. A high side driver in the ECM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. The ECM monitors the state of the generator turn ON signal circuit. The ECM should detect low voltage on generator turn on signal circuit when the ignition is ON and the engine is OFF, or when the charging system malfunctions. With the engine running, the ECM should detect high voltage on the generator turn on signal circuit. The ECM performs key ON and RUN tests to determine the status of the generator turn on signal circuit.
Your best bet take it back to the dealer .
Feb 25, 2018 | 2007 Chevrolet Uplander
I have this errors code to this car.p1637,p1638,p1699 and p1260.i change the batery and check all conectors .any ideea please?
What make , model an year vehicle ?
Generator L Terminal P1637? / Possible alternator problem The powertrain control module (PCM) uses the generator turn on signal circuit to control the load of the generator on the engine. A high side driver in the PCM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. When the PCM turns ON the high side driver, the voltage regulator turns ON the field circuit. When the PCM turns OFF the high side driver, the voltage regulator turns OFF the field circuit. Strongly suggest you take your vehicle to a ASE certified repair shop or the dealer .
Mar 15, 2016 | Cars & Trucks
Automobile headlamp bulb often burned
Filaments often burn out, the reasons are: voltage regulator has fault, the voltage is too high; bad contact battery wire, causing the generator no-load voltage is too high; the generator armature and field coil short circuit. If you open the light switch, the bulb burned out immediately, you should check the charging circuit has no circuit. If often burned out light bulbs, check voltage generator voltage regulator is adjusted too high. we also support wholesale bump at online store
Dec 20, 2013 | Cars & Trucks
DBSI325 will not put out voltage
Most of the problems like this are due to a failure of retention of the magnetic field to allow it to build up. Search Google for methods to "flash" the field. If you have had an accident of shorting or putting excessive load on the unit, rotating diodes of a brushless generator can be blown. Of the methods of flashing fields of the generators, I have had the most success with the method using TWO light bulbs in series between the utility mains and the generator. PLEASE be careful when doing this or handling electrical equipment where high voltage is present.
May 13, 2012 | Porter Cable PorterCable DBSI325 3250 Watt...
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
Code P0621
P0621 Generator Lamp/L Terminal Circuit Malfunction,,The Engine Control Module (ECM) or Powertrain Control Module (PCM) uses the generator turn on signal circuit to control the load of the generator on the engine. A high side driver in the ECM/PCM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. The ECM/PCM monitors the state of the generator turn on signal circuit. The ECM/PCM should detect low voltage on generator turn on signal circuit when the ignition is ON and the engine is OFF, or when the charging system malfunctions. With the engine running, the ECM/PCM should detect high voltage on the generator turn on signal circuit. The ECM/PCM performs Ignition ON and RUN tests to determine the status of the generator turn on signal circuit.
Aug 27, 2011 | Pontiac Grand Am Cars & Trucks
After replaceing the 6v battery do i need to polerise the generator? If so how?
no a generator will make its own power thats what made them so great hope this helps
Apr 23, 2011 | Ford Ranger Cars & Trucks
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
14 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
