Question about Garden
Castle Garden xdc140HD. Are there grease points or is it a closed spindle?
Cannot see with mower guard. guard seems awkward to take off.
Posted by Pat wslsh on
ray gallant
    Top Expert:
  • Garden Master
  • 70,831 Answers
GO SEEL A LOCAL DEALER AND ASK WE DO NOT SEE THAT BRAND HERE
Posted on Nov 13, 2020
5 Related Answers
Garry Clelland
  • 251 Answers
SOURCE: I just bought a new Husqvarna riding lawn mower,
hi. this is quite normal mike as the blades have a brake/clutch arragement.
Posted on Apr 28, 2010
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: I just installed 3 new GY21098 spindles on my lawn
Normally they come together already pregreased , How ever what I do, sense i don't really trust parts that pregreased, I try and get some more in there if I can. If not, you should be alright, sense they are put together complete, they come greased. Thanks Mike
Posted on Sep 10, 2011
Daniel
  • 123 Answers
SOURCE: Do the gy21098 spindles for
When changing spindles I always add at least 7 or 8 pumps of grease from the grease gun. Usually John Deere does not ship anything with grease. Daniel.
Posted on Sep 14, 2011
jarednyakund
Jared Nyakundi
  • 3 Answers
SOURCE: ive replaced a stock spindle with a drop spindle on my 95 gmc sierra and i can't seem to get the rotor on the spindle far enough to put the spindle castle nut on?
just remove the spindle as it slows the speed of your engine thus making it to consume a lot of fuel over a short distance
Posted on Aug 16, 2012
ssandoval83
  • 50 Answers
SOURCE: my garden castle mower 15/102 wont start, when i turn the key it just beeps, i have changed the solenoid but it keeps on beeping, when i put a screwdriver across the solenoid it will start but the bee
Check the starter switch and the wiring leading to the solenoid... Very similar thing happened with my john deere
Posted on Dec 23, 2014
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
Were are grease point for la 120 john deere riding mower located
wheels and spindles you may have greaseable blade towers
Jul 03, 2016 | John Deere Garden
How to lubricate the blade spindles
if there isn't a grease fitting on the side or in the shaft itself. you have the cheap spindles that can't be greased
Oct 18, 2014 | Garden
Can you grease the spindle on mustang
The factory spindles do not have grease fittings. I had to replace one of mine and the replacement did have a grease fitting. After seeing this, I drilled, tapped and installed grease fittings in the remaining two spindles. Ounce of prevention.....
Apr 27, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Grease fittings for spindles
Some cheaper mowers don't have grease zirks for the spindle bearings. If you cleaned off the deck and you can't see them, the only thing to do is remove some shields and keep looking, or check with manufacturer details to see if it even has them. A simple call to a craftsman repair shop should be able to answer that question.
May 22, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Do the gy21098 spindles for my La145 lawn mower deck come pre greased or do I need to add grease after installing
Sep 10, 2011 | John Deere 22HP VTwin 48" Riding Mower
Where Are The Greasing Points
Grease points on your mower should include the inside of the front wheels, and steering on both sides near the tires. Depending on the type of deck spindles and bearings you may have a few points on the deck to grease.
I hope this helps.
Aug 03, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Cub Cadet lt-1050 can't steer
If you purchased this unit from a home center etc. they never set them up or grease them ... if you can not steer this unit it was probly never greased at set up . you may need to remove the front spindles from the axle and remove the rust. before you reassemble be sure the grease fitting is not pluggedd up with rust as well , reinstall replace retainingclip( you will need to get a new ones) and grease your machine, also the mower spindles have grease fittings as well that need to be greased but the spindles need to be taken apart and the inner bearings seal removed to allow grease to enter the bearings
Aug 20, 2009 | Garden
How do i change outter tie rod
Prepare your tie rod and install the grease fitting provided with it. 1. Jack up vehicle and secure on jack stand 2. Remove wheel 3. Turn steering wheel so that access is best to the tie rod assembly. 4. Loosen jam nut on tie rod.Do not disturb or turn this more than what is needed to make it loose from the tie rod as this will be your rough reference point and at least close when installing new tie rod. 5. Remove cotter pin from castle nut where tie rod attaches to spindle assembly. 6. Remove castle nut 7. Remove tie rod from spindle assembly - Free with a hammer striking it on the castle nut shaft to drive it out of the hole. 8. un-thread tie rod from tie rod shaft holding the shaft still with vice grip or other pliers. 9. Install tie rod on shaft until it meets the jam nut. 10. Insert tie rod to spindle, tighten, and install new cotter pin in castle nut. 11. Tighten jam nut 12. Grease tie rod assembly 13. Install wheel and have aligned. Do not skip having this aligned regardless of how it drives, post repair as tie rods absolute length can vary from manufacturer to manufacturer. Your final alignment will not be accurate until it is set on a rack with an alignment machine.
Jun 04, 2009 | 1999 Ford Windstar
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
