Question about Electrical Supplies
2003 cameo 35ks3 RV, GFI 110v receptacle at bathroom vanity is causing the GFI on the 110v power supply from my house to trip. The GFI receptacle at vanity is new. what must be done to solve problem?
Posted by Eugene Dees on
Carl Rock
  • Electrical S... Master
  • 2,624 Answers
If the house GFCI trips only when the vanity receptacle circuit has power then likely the neutral and ground wires inside the vanity GFCI enclosure are in contact with each other.
To isolate the problem, suggest you pull the vanity GFCI receptacle out of the enclosure but leave all wires connected. Make sure no little hands can get near it. Then power on and see if it still trips the house breaker. If it doesnt trip then likely the vanity GFCI ground wire was touching the neutral.
Comment below for further assistance.
Posted on Aug 31, 2020
  • Carl Rock
    Carl Rock Aug 31, 2020
I have a screwball electrical wiring issue. I have 2 wires coming into a box with 3 conductors each, the box has 1 receptacle and one switch in it. The wiring is as such wire 1 comes from the pane and goes...
This is what I think is going on.
Pull the bathroom light and verify that there is only one wire going to it. I'm betting that it only has one 3cond and that it's the second one in your j-box.
Connect the 3cond from the circuit breaker to the GFI.
Pull a single black wire from the GFI over to the switch. The black in the 3cond to the light goes on the other side of the switch. White from the light goes to white on the GFI.
What the electrician did is power the light from the receptacle box.
I'd like to know if this corrects the problem and everything works.
Dec 08, 2017 | Electrical Supplies
I plugged a 30 amp power supply cord from an rv to a 15 amp house outlet to run a/c to rv . gfci tripped and wont reset. damaged gfci or something else?
A GFI outlet works independently of sensing an overload condition. Overloads are dealt with by the circuit breaker or fuse in your electrical panel. The GFI simply compares the current on the hot terminal (black or red wire) with the current on the neutral terminal (white or gray wire) and interrupts the current if there is more than 5mA (0.005 Amps) difference between the two.
Remove the load - in this case the RV plug - from the GFI outlet and attempt a reset. Make sure you're pressing the RESET button and not the TEST button. If it resets - you're all set. Reconnect the RV plug to a different outlet - preferably NOT a GFI type.
If it still wont reset, it is important to know that GFI outlets can be wired in such a way that any circuit extended to other outlets (lights, too) via the LOAD terminal screws will also be protected by the GFI. We need to be sure that there wasn't something else causing the fault. Check other nearby outlets for functionality. Remove plugs from any outlet found not working and attempt to reset again.
If it will not reset - it is possible that the internal sensing circuitry has been damaged due to such a large amount of current trying to pass. In this case, replacing the GFI outlet will be needed.
Oct 09, 2015 | Washing Machines
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
Where is the breaker switch on the Tuscany XTE
Probably near the spot where your electrical hook up cable comes out of your RV. Sometimes there is another sub-panel inside the RV ....Usually inside one of the smaller cabinet doors. Mine is under my oven/cooktop combo. Check the GFI switch too. Usually the plug receptacle in your bathroom. Push the test button....if it clicks out the other button....that means it wasn't tripped, if it doesn't click out the other button....you found the problem....press the other button to reset the GFI. Good luck and always work safely.
Sep 12, 2014 | Thor Motor Coach 2012 Tuscany XTE 36MQ
Grounded
This is my first thought. Do you have GFI in you house.
I lost power on my front porch one time, found out it was the GFI in my bathroom tripped. Reset it and everything was good. Nothing wrong with the GFI it was my kids playing with it.
Jan 21, 2018 | Home
My DW384 circular saw keeps tripping the GFI receptacle
Most houses have all the outdoor GFI outlets on one breaker...perhaps you can try another power tool with a similar draw to check if it is your saw or the GFI causing your problem. I can't see bad brushes causing a breaker to trip... the saw would just stop working.
Jun 20, 2010 | Dewalt 814 Inch Circular Saw
I've got 2 additions to my house; power to both went out last week. I have a tick tracer that I want to use to isolate which line from my panel goes to those additions (bathrooms) and is causing the dead...
If you have power out in parts of your house, look for a breaker or breakers that is/are tripped or if you have a fuse box, look there for blown fuse.
If no breakers are tripped, there is the possibility that you have a GFI in the circuit. Look for the GFI (google GFI if you dont know what im talking about) and reset it.
If an amp probe is what I think it is, it measures the amount of current going through a particular wire at a particular moment. If your power is OFF, or if you are not using any power on a particular line, the reading will be zero. I think you might be wasting your time with this tool.
If I misunderstood your question, please ask me again so I can try to answer again.
Thanks
a
Oct 02, 2009 | Measuring Tools & Sensors
Kenmore 417.40412700 triping GFI receptacle
Amperage pull too high. Increase the rating of the GFCI outlet - or there i an issue with the washer itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2009 | Washing Machines
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Electrical Supplies Logo
13 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
