I was watching my 65"led baird tv and the picture went on it its a blank screen
Posted by Catherine Weir on
5 Related Answers
Anonymous
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: sony bravia screen doesn't work but sound still
Ur Video converter board is dead,need a new one.
Posted on Oct 18, 2009
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: I was watching tv and the screen went blank. It
You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
Posted on May 15, 2010
Anonymous
  • 4 Answers
SOURCE: Sony Bravia - no picture,
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Posted on Feb 09, 2011
SOURCE: 55 inch led tv will not recognize my hdmi cable?
on you r remote there should be three hdmi settings just try each one it will likely work with one of them
Posted on Apr 16, 2012
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I have Samsung 46" rear projector TV the TV just went blank
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
? 2:57
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
How to fix vizio tv that turns on but no picture
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Baird tv has no picture but sound ok. picture lights up when turning on and off but then goes out.y
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Jan 07, 2014 | Vizio GV47LF Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
