Question about Singer Sewing Machines
Merrit 2404. Why doesn't top thread connect with bottom thread?
I removed the bobbin case and reinstalled it but now the top thread and the bobbin thread don't connect. The metal piece under the bobbin case is not moving when I turn the hand wheel.
Posted by Trina Mike on
ray gallant
    Top Expert:
  • Singer Master
  • 70,825 Answers
TAKE IT TO A LOCAL REPAIR SHOP
Posted on Nov 15, 2020
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Apr 30, 2017 | PfaFF Sewing Machines
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Singer stylist 477 bobbin case problem
a bit difficult unless you are a machine mechanic or have a detailed workshop manual beside you
I would not waste time DIY and would take it to a reputable sewing machine repair shop
Nov 26, 2017 | Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
I have a Singer
Which stitch are you using?
To check thread tension for straight stitches, use different colors of thread in your top thread and bobbin. If the top thread shows on the bottom of the fabric, turn the dial counter-clockwise (towards a lower number). If the bottom thread shows on the top, turn the dial clockwise. Do not adjust the tension too much (for example, go from 2 to 2.5 if increasing the tension) at a time; test another set of stitches. Alternatively, you can adjust the bobbin tension in the reverse directions. However, it's very easy to damage the set screw in the bobbin case so do this as a last resort. Since this is a vertical bobbin case, put the bobbin in and hold onto the thread. If the thread moves when you dangle the bobbin case, tighten the screw. Loosen the screw if the thread doesn't pull out of the bobbin when you hold the unit.
For zig-zag decorative stitches lower the tension until the puckering stops. Usually the top thread will show on the bottom of the fabric.
If the tension is not changing when you turn the dial, make sure that the presser foot is down. The sewing machine may need repair. The tension mechanism depends on a spring and that can break. See the Singer site for a parts breakdown and contact your Singer dealer for the parts.
If the top and bottom fabric are not moving at the same rate, you can get a different type of puckering. You may want to get an even feed foot if there are several layers of fabric.
The manual for the 3116 is available from Singer: http://www.singerco.com/uploads/download/438_3116.pdf .
I hope this helps.
Dec 08, 2011 | Singer 3116 Simple
Top thread is tight and bottom thread is too loose. How do you tighten the bottom thread?
You havent said what make and model this relates to.
But generally, you adjust the top thread and leave the bottom thread tension alone (unless it has been altered in error).
If your machine has a removeable bobbin case that goes into a front loading vertical rotary hook then you adjust a little screw on the bobbin case with a mini screwdriver. See this website for lots of great sewing machine tips and general help. http://sewing.about.com/od/sewingmachineparts/p/bobbincase.htm This page shows a removable bobbin case and explains which way the bobbin goes into it. If the bobbin is in the wrong way or not under tension this could be causing your stitching issues too.
Only 1/4 turn increments each time. To check tension on the bobbin case, put in the bobbin, pull the thread into tension spring, then hold the thread tail and dangle the bobbin case and bobbin (dangle test). It should hang in the air and the bobbin not release any thread. So turn screw up until you get it to this point but no further. With a gentle pull though, you want the thread to come out of it. Right to tighten, left to loosen usually.
If you search some of my other solutions I've covered the dangle test lots of times.
Jun 15, 2011 | Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Singer Sewing Machines Experts
dannydoesita
Michael Thomas
Michael Thomas
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
