Sound only no picture on hd channels only all other channels working correctly
Posted by Terry N Eirlys... on
Sarfaraz ahmad
  • 3 Answers
It problem may be in your channel networkno incoming signal to the television's antenna input or when no transmission is received from the broadcaster or you may have the Secondary Audio Programming (SAP) turned ON. The SAP feature allows your TV or Digital Cable box to tune in a second "track" of audio programming.
Posted on Aug 29, 2020
No sound on my tv
Look in the setup screen and see if you are sending the sound to the correct place.
Aug 04, 2014 | Toshiba 40BV702B 40 inch full hd lcd tv...
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
No Non-Hd sound
a2d70c9.jpgdid you remember to put audio leads in
Nov 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
No sound on hd tv on just one station
put tv on ch 2 and locate MTS button and press it till the sound comes back min English
Electrode.
Nov 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
