Question about Kenmore Refrigerators
Kenmore Upright FrostFree Freezer 26072, 13 yr old. Get 1/4-in solid ice layer over most of the floor of the freezer. I asked question about door ice earlier.
Posted by Cheri Hewitt on
Steve McQueen
    Habit-Forming:
  • 24 Answers
Sounds like the freezer drain is stopped up. Clear the ice with a hair dryer, find the drain hole, clear it compressed air.
Posted on Oct 17, 2020
Leaking water on floor
The defrost drain is most likely frozen or clogged. I put together some instructions on clearing this for refrigerator/freezers and it applies the same to all freezers with drains. Take a look and let me know if you have questions.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 05, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Water on floor temperature rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Need correct setting for 30 yr old upright Kenmore freezer
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Feb 17, 2009 | Frigidaire Upright Freezer FFU12F2H
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Mar 30, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
