Question about Garden
John Deere sx95. Why doesn't it start? - Garden
Posted by Kent phillips on
  • Carl Rock
    Carl Rock Nov 18, 2020
    No crank or crank no run?
HRHabib
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Https://youtu.be/mGQciTRv7WU
Posted on Nov 20, 2020
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garden Master
  • 37,191 Answers
Dead battery?? bad fuel?? no spark??
Posted on Nov 17, 2020
5 Related Answers
Anonymous
  • 178 Answers
SOURCE: nothing engauges when you turn the key.
first check all fuses if good go to your starter solenoid take off the ignition wire usually i terminal with someone helping have them turn key to start holding while you take your test light to see if the wire lights the light if it lights put back on the solenoid now test the pos cable on the starter should have juice if not it is fed of the starter solenoid trace all wires back search for burnt inline fusible link there white or black oval shaped test both sides of wire if one side has juice the other doesnt the link is junk they usally burn thru were it looks like a welding arc check all also pull on both sides of wire to see if they come out of link goodluck
Posted on Sep 14, 2008
6ylucy
Dick Snider
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
Mike Squire
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
dannydoesita
  • 777 Answers
SOURCE: john deere stx 38 with black deck, will not do
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
Posted on Jun 17, 2011
HOW TO REPLACE A FUEL SHUTOOFF SOLENOID ON MODEL SX95 JOHN DEERE GARDEN TRACTOR
Here's the link and I'm sure you will get the solution of your problem -
Best Manuals
Jul 30, 2018 | John Deere Garden
My john Deere sx95 blades not engaging plz help
When the blades on my John Deere fail to engage, I climb off the seat and look to see if the belt is still on. Belts get thrown, especially if you have too much grass on top of your deck. They also get stretched too much. I took a permanent marker and drew a picture of the direction of the belt around all of the pulleys. (Most mowers have this somewhere like on the deck or under the hood but I did my own).
Apr 09, 2015 | John Deere Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
Manual for john deere sx95
Jul 06, 2009 | John Deere Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
