Trying to link my techwood tv hdmi to my sky q box. The leads are in the right ports yet need help on how to configure it using the techwood remote. My other tv when linked up goes straight to sky opening screen straight away yet when I try with the techwood tv it shows a blue screen with Ext-1
Posted by Rich on
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Jan 27, 2009 | Televison & Video
Connections
conect ps3 audio throw optical
Dec 26, 2007 | LG MU-50PX10C 50 in. Plasma HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
