Question about Frigidaire Refrigerators
How can I stop beeping?
The refrigerator and the freezer are not working.
Posted by Jose on
David Spradling
    Top Expert:
  • Frigidaire Master
  • 11,670 Answers
Beeping is alarm that inside not cold enough
Posted on Nov 17, 2020
5 Related Answers
Anonymous
SOURCE: THE FREEZER IS WORKING BUT NOT THE REFRIGERATOR
your defrost system is malfunctioning un plug refrigerator for about 2 hours replug and check if it makes a difference check if fan in freezer is working , you may need atechnician .
Posted on Mar 06, 2008
douglas smith
  • 1462 Answers
SOURCE: Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Posted on Oct 15, 2008
farfield
Farley Redfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
Anonymous
SOURCE: Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Posted on May 02, 2009
orders64
SOURCE: Refrigerator does not work
The plug for the damper door is not connected properly
Posted on May 24, 2009
Freezer working ok, but the refrigerators not working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
MODEL LRS 206 GP FREEZER IS WORKING WELL AND THE FRIDGE IS NOR WORKING WHY ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 05, 2011 | LG LTC22350S (221 cu ft) Top Freezer...
Freezer cold and working fine, fridge not getting very cold. Have defrosted freezer, removed freezer back cover fan all working o.k. Jim
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 24, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Freezer is working fine. The refrigerator is not
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Freezer working - refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dtiurt7
Oct 27, 2009 | Maytag MZD2766GES Side by Side...
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Dec 24, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
might sound stupid but is the fridge controled by a separate thermostat inside the fridge
Jun 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
