Televison & Video Logo
Amanda Lyman Posted on Aug 28, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How I get off a parental lock code on an element tv when the default code does not work. I have a universal remote but the code is wrong it was a gift from a friend
David Spradling
Level 3:
Top Expert:
  • Element Master 13,522 Answers
  • Posted on Sep 19, 2020
David Spradling
Element Master
Level 3:
Top Expert:
Answers
13522
Questions
0
Helped
929164
Points
28390
Try doing a factory reset that should clear it
Sarfaraz ahmad
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 29, 2020
Sarfaraz ahmad
Contributor
Level 1:
Answers
Questions
0
Helped
439
Points
5
Press the Menu button on your remote control.
Select Settings.
Highlight System and press OK/Select.
Select Parental/Purchase.
Enter your Parental Controls PIN.
Select Parental Preferences.
5 Related Answers
A
Anonymous
  • Posted on Jan 02, 2008
SOURCE: Element LCD TV FLX-3210
Try 004. That worked for me
A
Anonymous
  • Posted on Nov 07, 2008
SOURCE: Need 3-digit code for tv remote
I'm looing for the TV brand to choose so I can find the right 4-digit code for an Element TV (Element is not listed)
Anonymous
  • Posted on Jul 15, 2009
SOURCE: Cannot program Dish Universal Remote for Emerson TV
This worked for me. I had to scan down quite a few times but eventually my tv turned off and I set the code with the # button. It may work for you too and save you some money on a UR.
http://www.satellite-tv-planet.com/DishNetworkRemoteControlProgramming.htm
Scan For Device Codes If the code for the device you are programming is not listed in the user manual or on this site, try these steps to scan the remote controls memory for device codes.
1) Turn the power on the device on
2) Select and hold the mode button for which you are programming, such as the TV button, on the remote until you see all the lights of the mode buttons flash. Once you let go, that mode button that you chose should now be blinking. When using the Aux mode button only use the number pad to enter 0 for a second TV, 1 for a second VCR/DVD, 2 for a amplifier, tuner, or cable box. Then press the STAR (*) button.
3) Press the power button on the Dish Network remote control.
4) Repeatedly press the UP or DOWN button on the remote to scan for the correct code (do this slowly so you do not skip over the right code for your device). When the correct code is reached the device will turn off.
5) Press the POUND (#) button to store the code in the Dish Network remote.
6) Press the power button to turn the device back on and try using other buttons on the remote to make sure that they also work. Sometimes the power button will work while others may not.
Anonymous
  • Posted on Nov 08, 2009
SOURCE: Default codes for parental control
I found in an online manual for the Polaroid 2632, code is 8202 and it works I just unlocked my own tv with it
Anonymous
  • Posted on Dec 21, 2011
SOURCE: What is the tv code for an element tv if I program
FOLLOW THIS LINK IT WILL GET YOU ANY REMOTE CODE YOU NEED. http://www.urc.philips.com/
I was lost my airtel digital tv parental control pin how i get to recover the forgotten pin
1. You might have to enter a PIN code to unlock this screen. Enter the PIN/CODE set by you or 0000(also try 1234) if you have not yet changed the default PIN.
2. Its easy, first press the MENU button on your universal remote and go to Settings->Child Lock/Parental Control/Security. You might have to enter a PIN code to unlock this screen. Enter the PIN/CODE set by you or 0000(also try 1234) if you have not yet changed the default PIN.
I have a RCR universal remote. It turn the tv on/off but the red lock remains on my apex 2011s. What do I do?
The Apex prompts you to
enter a 4-digit code when you set up parental controls. You can block programs
according to their MPAA ratings or their content designations, such as V for
violence or S for sexual situations. You can override parental
controls on most Apex models by simultaneously pressing the F and mute buttons
on the remote control. If you own Apex models GT2011J or GT2011S, hold the
remote\'s display button for ten seconds. The red key will vanish and the V-chip
will unblock your program.
Apex\'s default parental
lock control code is 6688, so if you haven\'t set a new code, entering 6688 will
remove the red key and unblock your program. If you\'ve set a new password and
forgotten it, entering 3308 will reset the code and unblock your program. For more, http://electronicshelponline.blogspot.com/
Can I get the parental lock key turned off? We do not have the original remote. We are on UVERSE. ALl of my remotes (two universal and one Uverse) seem to be partially locked also. I can turn TV on and...
What you need to do is to get into the Main menu. Then goto default settings Change to default settings It should then behave. However if you need a pass Try 0000. IT should work..
hope this helps
2helpful
The buttons on the front of the tv are locked how do i unlock them. i bought this tv from a friend and they dont have the code
Hello there,
The default code is 0000 but this only works if a code has not been set. You will need the RCA remote or a universal remote programmed to work with the TV to enter the code.
If a code has been set and forgotten you can reset the code by pressing VOL+ on the remote and the CH+ button on the front of the TV simultaneously. However, you will still need a remote to set a new code. When asked for a password, simply enter a new code - I'd suggest setting it back to the factory default 0000.
The child lock then needs to be disabled from within the on-screen menu. This option is located in the Preferences menu and is called FPA Lock. This should be set to OFF assuming you don't wish to use the parental control feature. You may be asked for a password when switching FPA Lock off, so it's better to change the password first, as above.
Please try this and post back if you are still unable to remove the lock or if you don't have a remote.
Hope this helps.
Regards,
BElectric
Parental Code Lock is on. The remote does not work. Help!
u can buy a chip universal remote control from walmart and programed to this tv and then acces to the parent control
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
6helpful
2answers
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
4answers
Parental controls
wuts the model # on the television
4helpful
Parental Controls
I am having the same problem. I have a Mintek 2110, but lost the remote control. I found this code on the Time Warner Cable site. 2096. I'm going to try and plug it into my universal remote this evening. If that works, the default passcode should be 88888. That's what I remember my code being years ago.
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
